Help me ID this Heads ???
Old Oct 26, 2007 | 06:58 PM
mighty-z28's Avatar
Question Help me ID this Heads ???
I got this from a friend but he didn't remember anything about them other than they were ported #806 and they were O-Ringed
I want to put this on a 2000 SS and I already bought a set of Patriot Gold Springs w/ TI retainers, Chromemolly 7.400" pushrods and I"m planning to use stock rockers and valves...
My cam is a 232/232 .598 .598 112 LSA.
Please help me find out what kind of work this heads had and what should I do before ensamble them and put them in my car... how can I messure the Compresion ??? etc...
Thanks in advance for your help !!!
Old Oct 26, 2007 | 07:04 PM
brad8266's Avatar
To measure the chamber size for compression calculations you will probably want to take them to a machine shop and have them measure the size with a beaurate(sp?). I have measured chamber size myself at home though using a syringe.
They do looked to have been worked over and the W2W on the side would indicate that wheel to wheel did work on them.
Old Oct 26, 2007 | 07:07 PM
mighty-z28's Avatar
Cool man !!! Thanks for the info...
did you like my set up ??? do you know what kind of HP will I get from this heads ???
Old Oct 26, 2007 | 07:17 PM
mighty-z28's Avatar
Does this look like stock size valves to you ???
Old Oct 26, 2007 | 07:24 PM
brad8266's Avatar
Usually worked over heads have somehwere in the 2.02intake/1.57exhaust range on valve size.
Old Oct 26, 2007 | 08:24 PM
ISeeRed's Avatar
you realize to use these you have to get new valve covers and brackets for the coils right?
Old Oct 26, 2007 | 08:25 PM
ISeeRed's Avatar
Oh, they take different gaskets too because these are 97-98 heads.
Old Oct 27, 2007 | 06:44 AM
WS6Drop's Avatar
Those are perimeter bolt heads for the valve covers, and you have centerbolt valve covers as metioned. These are from a 97 or 98 Ls1.
Old Oct 28, 2007 | 04:13 AM
mighty-z28's Avatar
Yeah I have the perimeter valve covers and brackets already, I just want to see if any of you guy can explain the work that this heads have by the numbers on them and what valves do I need, seats, etc.. I don't know anything about heads
Old Oct 29, 2007 | 03:07 PM
mighty-z28's Avatar
Anyone ???
Old Oct 30, 2007 | 08:00 AM
mighty-z28's Avatar
I need some more info, please...
Old Oct 30, 2007 | 01:00 PM
Vrbas's Avatar
What did your friend say? Where did he get them?
Old Oct 30, 2007 | 08:02 PM
mighty-z28's Avatar
He has no idea but I contacted the guys from wheel to wheel and they say that they didn't ported them so I still need to get some info about them....
No one has any ideas ?????
Old Oct 31, 2007 | 12:48 AM
Vrbas's Avatar
Got any pics of the intake runners? Maybe you could try to identify them by that using the website below...
http://www.gmhightechperformance.com...ide/index.html
Old Oct 31, 2007 | 09:26 AM
mighty-z28's Avatar
Thanks Vrbas !!! I know that they are #806 heads but I want to know what kind of work this ones had by someone that knows about heads when he looks at the pics... Let me know if you guys need some more pics and from were
Thanks
Old Oct 31, 2007 | 09:46 AM
Vrbas's Avatar
Try PMing a few sponsors on the board, Predator Z even.
Patriot
TSP
PortPros
Thunder
Old Oct 31, 2007 | 01:58 PM
5.3LJimmy's Avatar
Those heads have a massive amount of material removed from the intake bowl area, and the o-ring grooves are for boosted or heavy nitrous use. Those huge ports are gonna stall out and kill the bottom end power on a stock cube normally aspirated engine. The intake valve is also very large and may not clear the bore on a stock engine. I wouldn't use them.
Old Oct 31, 2007 | 02:42 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Take some pics of the runners for us. I just want to see what they look like.
Take the heads to a machine shop and have them flow them for you. You can measure the chambers and runners with a buret.
Old Nov 1, 2007 | 01:04 AM
mighty-z28's Avatar
I'll get some pics tomorrow
Old Nov 9, 2007 | 05:29 PM
mighty-z28's Avatar
Here you go :
