F13 cam, 7.4 pushrods or 7.425?????
Just installed the Futral F13 cam with standard 7.4 pushrods, wondering if 7.425 would quite the valve train down some. Im using the Patriot Dual spring set up and the motor is a standard LS6 motor all stock. Any have any luck with this?
BTW I know how to check for proper PR length just hoping someone had some luck with this to save me some time. Thanks
Restricted User
I've heard some cams like the lingenfelter performance have a smaller base circle on the lobes so longer PRs are needed but I don't think the futral cams are like that. If getting rid of the sewing machine sound is what you're looking for you'll have to upgrade rockers.
Stock PRs are actually 7.380 not 7.400, so you make up .020 difference there. Going to 7.425 would put you within .005 of stock preload (below stock). Or you could mill the heads .030 and be spot on ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Im running 7.400 PRs with heads milled .040, which puts me .010 over stock preload, and im very happy with the valvetrain noise.
I just put a Lingenfelter cam in my car with LS6 heads with LS1/2 Valves. The base circle on the cam IS smaller and I used 7.425" with the new YT's. Not a sound....It's super quiet.
On a side note if you have LS6 valves they are .6mm longer and should not need anything other than the stock 7.400". (Unless of course your heads are milled or you went with a much thinner gasket)
Logic told me to use longer pr's because of the smaller base circle of the cam, but I listened to Allen and put the 7.4's in. With the SLP dual/dual exhaust my car is fairly quiet and the clattering with the 7.4's annoyed the **** out of me, so for the little bit of money involved I made the change over to 7.425's. I'm using CC 918 springs from a few years ago, not the ones that are having problems now.
So nobody has said for sure if Allan's cams have smaller base circle's?
The cams are hydrolic lifters (stock) and the 7.40 are a hair noisyer but car will run better with the 7.40 (looser) but you will get a little more motor noisy but you dont want a stock car when you put a performance cam in a car. I run 7.40 in all the cars that I have done unless they start decking the heads or the block. My set up in my car is a Stock LS6 with stock heads and makes 456 rwhp and went 11.13 at full weight no weight reduction before Fast 90 intake that was with LS6 intake and MTI Throttlebody at Einglishtown NJ. Good Luck
