Comp Cams said I had to?
+1, always check it yourself
He is still saying there is no way it should hit . That is why i called comp and the said it will hit. Seems like some where in there since it is a comp cam that Jason would have know this .
Know with me asking this and wanting a assurance that is didnt and it did does this make him responcable for the labor cost of having it redone?
There are too many variables for anyone to say for sure about PTV clearances & pushrod length. Both need to be measrued at the time of the build/install.
If the installer doesnt have the time to go the extra step to verify these things, I think someone else should have done the work.
Now Jason may offer to help out with some of the cost, but I dont think he is obligated to. Im sorry man, I feel your pain, chuck it up to a learning eperience. You wont make this mistake ever again! :-)
So that is why i didnt take the time to do this . I took the mans word on it. So dont give me this **** that i should off checked. Because why in the **** would he send me something that wasnt gonna work. I never second guessed the man.https://ls1tech.com/forums/generation-iii-internal-engine/758749-patrick-g-tuned-my-trak-cammed-prc-ls6-2-5-s-car-results-inside.html
same setup his **** worked?
You know and now my old lady is up my *** so bad about this **** . I just found out friday that she called Jason or John and snapped. I have been renting a car . Staying at my buddies cause we are fighting. So yeah the ******* stress level is high and bullshit i dont need. I just looking for some advice here is all. why would it work on one car and not the other.
I off to take a trazidone and have a six pack .
1- Flycut
2- Sell the TV3 and get a smaller cam. 228/228 112+4 will fit with no issues.
3- Work out a deal with TSP to send you the 228R cam for free.
In Your first post You said You took it to the professionals!
I must dis-agree, anyone worthy of calling themself a mechanic knows if You are having piston to valve contact with a .040 head gasket that going to a .052 won't cure anything!! Even if it was enough to make it clear, You still will not have the minimum clearances necessary!
It is time to have the car towed again! Run before they really screw up Your car.
Just My .02 cents, hope others chime in as well. Carl.
That is why degreing a cam (even with non adjustable timing chain) will give an idea of the true cam specs or if it is installed properly
The options I gave you are cost effective. Try to work something out with TSP, I would go with the smaller cam. The 228R will fit.
I'm not too crazy about flycutting (has to be done properly), a thicker gasket is not enough clearance.
I dont know what else to do. Yes there was on two gaskets with the mls not sure why. But even with the .052 its still hit but it seem to be only one cylinder # 4 exhaust and take that back # 2 just barely made a mark. He said he can recess them .o25 To .030.
I have to say if it wasnt for bad luck wouldnt have any at all. I am kinda hoping i get to sleep in my own bed soon . lol
Thanks for the input guys . I will let you know what happens.
