Balancer removal is being a biatch!! Help!
That has to come off first , then use the autozone Chrysler tool refered to in the above posts or any other tool designed for your balancer.
You can use the rod supplied with the tool or do as I prefer and place an allen head a cap screw into the crank snout.
The idea is not to damage the threads in the crank.
I'm sure it will pull off if you follow the process.
When you re install do not hammer the balancer on .
Clean the inside of the balancer and crank snout.
Put a very thin coat of never sieze on the crank and HAND START the balancer back on as stated in one of the previous posts.
There is a member here (do a search) who sells a slick tool that will pull the balancer on the correct way and not damange the crank.
If not use a long rod and washer to pull it on .
Do not hammer it on or try to use a longer bolt to push it on.
Good luck, let us know how you make out.
Ryan
https://ls1tech.com/forums/generation-iii-internal-engine/808118-anyone-rent-pulley-install-tool.html #12
But I have my own install problems, which I will post up separately.
