A good cam for a daily driver?
Old Nov 6, 2007 | 09:50 PM
thebart455's Avatar
Default A good cam for a daily driver?
im just looking for a cam that sound good and gives me some decent gains. also want to be able to drive it daily
Old Nov 6, 2007 | 10:55 PM
santiago's Avatar
g5x3 114
Old Nov 6, 2007 | 11:40 PM
litle88's Avatar
HOTCAM!
I just got a Fast 90mm intake Delphi 85mm MAFS and UMI Tb and netted 405 at the wheels.
Old Nov 7, 2007 | 04:02 AM
SOM 02's Avatar
i had the ms3 in my with my old setup never had a problem driving it any where.
Old Nov 7, 2007 | 04:25 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Get a cam that has positive valve overlap and smaller duration and you will have sound and driveability all in one shot. maybe like a tqr v2.
Old Nov 7, 2007 | 06:07 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Hotcam, TR224 comes to mind.
Old Nov 7, 2007 | 06:46 AM
lastcall190's Avatar
My Pat G custom is nice. Clip in sig; 224/226 on 111+2
-J
Old Nov 7, 2007 | 09:35 AM
thebart455's Avatar
i dont know alot bout these cams yet where its the power come and and the torque curve?
Old Nov 7, 2007 | 09:57 AM
EarlSS's Avatar
-J
Sweet sounding cam you got there... What kinda numbers did it put down?
Old Nov 7, 2007 | 11:28 AM
brad8266's Avatar
I have a 232/236 112LSA (basically a torquer cam) and its great for daily driving, although i have a nice set of heads and it is setup with fairly high compression. Made over 450 HP and 415 ft-lbs. I drive it everyday and the most unstreetable thing on the car is the agressive clutch I have.
Old Nov 7, 2007 | 11:33 AM
SSNISTR's Avatar
Futral F10 or F11.
Old Nov 7, 2007 | 11:39 AM
SSwt00SS's Avatar
Comp or TR 224/224 .581/.581 @112lsa...that's what im runing and this is what im putting down...M6 car...H/C/I/E...
Old Nov 7, 2007 | 12:07 PM
375/361. I believe there is definitely at least a little more in it. Going to track soon (for the first time, should be comical)
-J
Old Nov 7, 2007 | 12:08 PM
Nostang's Avatar
I have an 02 Z28 6 spd. with all the bolt ons (no electric wp) and a cartek 2x cam for a daily driver. Has a noticeable idle but is close to stock as far as drivability. The cam with all the bolt ons made 402rwhp and 373rwtq. I would drive this car anywhere.
Old Nov 7, 2007 | 01:03 PM
John02Hawk's Avatar
Anything 230/230 and smaller will do just fine for most daily driven cars.. Check out some of the stickies on the top of this forum for all the info. you might need.
Old Nov 7, 2007 | 01:13 PM
RedRallyeZ's Avatar
TR224 or 228r, both have nicer flatter torques curves and the power comes on sooner, easier drive, torquerII is nice too with a little higher torque curve
Old Nov 7, 2007 | 03:26 PM
NEMESISVETTE's Avatar
I have the lunati voodoo 222\228 .567 .567 113 with dart heads 447rwhp . very daily driveable
Old Nov 7, 2007 | 03:50 PM
Bryan @ Speed Inc.'s Avatar
for daily driven cars, i like 220 - 224 cams.
220/112
222/112
222/114
all good.
Old Nov 7, 2007 | 04:00 PM
KEE AUDIO's Avatar
TR220 114LSA driven daily for 3 years with no issues. Vengeance tune, LT Dynatech headers, Yank SS3600 stall, 3:73 gears. Sounds like a much bigger cam with the SLP LM and sounds like a tuned muscle car with GMMG exaust. Dyno'd at 345hp and 379tq unlocked. This is through decked 98 heads and a stock LS1 intake with a ported TB. So there is plenty left.
Old Nov 7, 2007 | 07:12 PM
Ragtop 99's Avatar
98' Z-28 m6 K&N air filter, no cats, 4:10 gear, center force clutch, hurst shifter
Do you have headers or stock manifolds? If you have stock manifolds you can throw out most of the advice given in the above posts.
