Help me pick a cam & make a parts list
#41
If you did my same cam on a 112, would you have degrees advances in the cam? Say +2 or +4
With my cam on a 112+2 you will 6* of overlap
With my cam on a 112+4 you will 6* of overlap
But the VE are different. my cam on a 110+4 has 10* of overlap
So what are you thinking then?
#46
yea i know all the small extras will add up. I also know i have to have money for a tune and install. Nick from newtech has tuned my car once before so a retune is cheaper.
Now i just need to pick a cam!
#52
dude, N/A its still a beast. it might not have all that "low end" the 224 is famous for.. but when your racing where are your rpms at? i sure hope their higher then 4 grand.. and thats where the torquer 2 makes all the difference. i DD my car every single day, in seattls pouring *** rain and the car has pretty good manners even with stock 3.42 gears. but whatever you do if you want it smaller then a T2 get something with split duration for the spray
#59
So i need.....
Cam
Springs
Pushrods 7.425
Retainers
LS2 timing set
LS6 ported oil pump
Cam Gasket kit
Longer crank bolt & UD pulley
Am i missing anything?
Cam
Springs
Pushrods 7.425
Retainers
LS2 timing set
LS6 ported oil pump
Cam Gasket kit
