Help me pick a cam & make a parts list
#63
you're missing seats/seals and locks... You will need oil pump O-ring and Water Pump gaskets. What size cam did you decide to go with? The 7.425 PRs are suppossed to quiet the valve train, the real way is to measure the base circle of the cam that will tell you what size PRs to go with.
#66
#68
Dont the water pump gaskets come with the cam install gasket kit? ok i'll add the oil pump o-ring. I decided to have patrick g spec the cam. I just have to take care of a dew things and i should have the specs next week. Im really like the 228/232 range but we'll see. I would like to have a quiet valvetrain for sure
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#69
You know what i think your right about the water pump gaskets in the kit..... when ever Patrick Specs cams, he does the 228/232 for some reason. I chose that one on my own
in my idle vid, that is what the valve train will sound like. When the motor get warm, it is a TAD bit louder.......
#72
LS1 Tech Administrator
You have to look at total overlap and not LSA when it comes to tuning. Any 346 under 15 degrees of overlap is fairly easy to tune. Under 8-10 degrees is cake. 4 degrees of overlap makes people wish they had gone bigger (usually). You just need to do the tuning yourself or find a competent tuner.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
#73
I want a nice lope though. I like the way torched 02 ta's cam lopes alot
#74
For some reason my cam was bit harder to tune. the 10* was acting like it has 20* of overlap to it. I must have a motor built on Monday
Just take your time with this. i for 2 weeks straight 8 hours a day did research and read sooooooo much info. And i asked a lot of questions....
Good Luck
#76
Like Patrick said, it is not the 110 that makes it hard to tune, it is the amount of overlap the cam has. Like mine has 10* in it, the one that your specing has 6* in it. So yours should me easy to tune.
Good Luck
Good Luck
#77
http://www.mphparts.com/mm5/merchant...Category_Code=
Bam. There's your ~900 cost. IMO that's all you need. I would def do the Oil Pump and put an LS2 chain on there (chain is <$100).
I spent about 1 month deciding to get a cam, and about 10 minutes deciding which one. I just sent Pat G a request and he got me set up. I wish I went with a bigger cam at this point![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
-J
-J
#78
yea and you will learn how to read ve's and will learn how they ve's affect the way teh cam preforms
i dont see any one else with the cam i specd out "with the help of pat and pred" because i have specific things i want that others may not
#79
-J
-J
that tuned or untuned? idle speed? what lsa?
#80
That was untuned. Idle speed was... who knows
I can get you a clip of tuned idle ~800 right now if you want. LSA is 111 with +2 advance.
I gotta say some days I wish I went bigger, but this cam drives absolutely AWESOME on my stock 342s. Lot of get up and go, and pulls hard up top. Car skates around all the way through 2nd gear on the 315s (shitty-tomos... dur).
-J
-J
