g5x2 and streetability
Old Jun 19, 2003 | 06:25 PM
OSoSlow's Avatar
Default g5x2 and streetability
Would I be able to run this cam with some stage 2 ported 5.3l heads and not have to worry about piston to valve clearance? Also I've read about people doing emissions tunes. Would I be able to do one of these and pass smog? I want the power of this cam, but have to keep the car streetable, just enough to get to school and work and to mess around with the local import scene on the weekends.
Old Jun 19, 2003 | 06:34 PM
BIG PD's Avatar
Default Re: g5x2 and streetability
i am also curious if this cam will work with 5.3 heads, but also if they will work after the heads are milled .020". thanks
Old Jun 19, 2003 | 06:54 PM
deviate42's Avatar
No chance at smog with that cam.
I've heard of 224/224 passing and some 230's.
Old Jun 19, 2003 | 07:35 PM
BergerMan's Avatar
If you "do not" want to cut your pistons, "do not" get your heads milled at all. A (.0010")(one thousandths) cleanup pass will be fine, but if you go .020" (twenty thousandths) or .030" (thirty thousandths) you will have PTV problems and definitely have to cut the pistons.
Old Jun 19, 2003 | 08:41 PM
OSoSlow's Avatar
Dont the 5.3l heads not need to be milled to get 11:1 compression? And didnt chris ARE 360 pass smog with a cam bigger than the g5x2? With non milled heads and non cut pistons, Would the g5x2 work with the 5.3 heads on an otherwise stock motor?
Old Jun 19, 2003 | 08:46 PM
BergerMan's Avatar
Yes, they will work fine. If they are not milled you will be pretty close to 11:1, probably around 10.8 or so. Its always a good idea to check the PTV clearance just for the piece of mind though.
Old Jun 19, 2003 | 09:12 PM
OSoSlow's Avatar
So the g5x2 is streetable? Who was the person that passed smog with a giant cam but used a ls1edit tune to do so? What about the X1 cam, will that have any chance of passing and make good power with the 5.3l heads?
Old Jun 19, 2003 | 09:23 PM
JF WS6's Avatar
The G5X-2 is a 232/240 cam. Chris's is around 230 or so (and he had to do a few tricks to pass emissions like raise his idle speed above 1000 rpm's, he had ARE retune it and a couple other things I don't remember right off hand.)
If you are mostly concerned with emissions, the G5X-2 is NOT the cam for you, it's one of the biggest out there right now. Get a 224-228 cam or so. More duration = more valve overlap at idle which = more unburnt fuel flowing out of the engine through the exhaust which = failed emissions if you have to do a sniffer test. Any duration in the cam you add past 224 is just going to take you more and more near to failing the sniffer test.
Old Jun 19, 2003 | 09:45 PM
OSoSlow's Avatar
What about the x1 cam. It seems like a good reverse split. If not i was thinking about getting a comp cam custom reverse split grind. I dont care about lope so a 112 lsa is find. What is the biggest possible reverse split i can run and still pass. I wanna have about 430 with long tubes, true duals, all the bolt ons, and some ported 5.3l heads in an m6. Another thing are the 5.3l heads a good deal for the money and will they work well with a large reverse split.
Old Jun 19, 2003 | 10:15 PM
LEO's Avatar
LEO
The X1 on a heads/cam pkg more than likely will not pass an emissions test.
Old Jun 20, 2003 | 01:01 AM
u8dusst's Avatar
I know someone will ignore all visual for me to pass smog, but it has to pass the sniffer but he could care less on how I do it. So what im wondering is, do you think there would be a chance of passing if I had a custom H-pipe made with 3 cats per side? For use only when emissions time comes around of course. I have a buddy who owns a muffler shop so that isnt a problem either.
BTW, All this with the G5X-2 cam and cali emissions.
Old Jun 20, 2003 | 02:06 AM
OSoSlow's Avatar
Im was just wondering how the 1 would work. Whats the largest reverse split i could possibly pass with, using an emissions tune.
Old Jun 20, 2003 | 02:14 AM
Mike K.'s Avatar
For emissions you may want to stick to a 224 on a 114 lsa, Any bigger and you will probably fail.
Old Jun 20, 2003 | 02:45 AM
bigSS's Avatar
I have the G5X2, drive it pretty much everyday, and its fine. I don't know how you define "streetable" ... but with the G5X2 my car doesn't die or hunt for an idle (when warmed up), so that means its streetable to me.
Old Jun 20, 2003 | 11:13 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Let's make a list of what passes for sure.
This is assuming you have cats on the car...
224//114
222/224//113 my old cam passed in WI
220/114
Has anyone passed with a 228/228/114?
Old Jun 20, 2003 | 01:20 PM
2001 Pewter WS6's Avatar
Restricted User
I passed this past week with a 236/240 112lsa. But then again I was exempt for driving less than 5000 miles a year...
Old Jun 20, 2003 | 01:29 PM
OSoSlow's Avatar
I'm not worried about what LSA, so a 112 would work. I want to find a cam that could get me around 430 with absolute speed stage 2 ported 5.3l's, long tubes, dr gas 3 inch x pipe, all the bolt ons, ls6 intake, etc. I'd rather do an emission tunes and have to work to pass smog than get a smaller cam that doesnt produce the same numbers. I dont think anyones responded about the x1 cam. I would think thered be a way to run a small gap in duration so that theres enough overlap that i can somehow cover it up. This is a street car, but i want to take it to the track weekly, so manners arent that big of a deal.
Old Jun 20, 2003 | 01:54 PM
BurnOut's Avatar
Streetability is not the same as street legality...
Anyhow, you will have trouble passing a sniffer with any cam over 220 @ .050 on a 112, IMO... the overlap means that idle vacuum will be (relatively) low, which in turn means that (compared to a cam with a wider lobe sep) you car will spew all manners of nastiness at idle, according to the sniffer.
As for emissions tunes, I'm not really sure what that means... when the vehicle is warmed up (in closed loop), the computer is attempting to achieve stoich anyhow, regardless of the WOT tune. Most PCM tunes actually lean out the mixture at high throttle anyhow (factory WOT A/F is @ 12:1, tuners usually shoot for @ 13:1). Pulling timing would hurt emissions as well...
Old Jun 20, 2003 | 03:40 PM
Stone0fFire's Avatar
dude, if you have the hookups,
have him run a civic,
and just enter your info
BAM! with flying colors!
Old Jun 20, 2003 | 05:02 PM
FASST's Avatar
Forget the Civic. Get cutouts and ljust eave them open.
