LS1 Injector retainer clip part number?
Old Dec 18, 2007 | 11:04 AM
chpmnsws6's Avatar
Default LS1 Injector retainer clip part number?
The LS2 part number is 24503227 but is the ls1 clip the same?
Old Dec 18, 2007 | 11:56 AM
seawolf18's Avatar
I tried to get new retaining clips when I did my head/cam swap, and the dealer here said they only came with new injectors, and I couldn't buy them stand alone. I dont know if there were blowing smoke up my *** or if that is the case.
Old Dec 18, 2007 | 02:02 PM
chpmnsws6's Avatar
Hmmmmm, Maybe I shouldn't of thrown them away
Old Dec 18, 2007 | 02:18 PM
Bad Blue WS6's Avatar
man,,i posted this a lonnng time ago,,, (i lost one doing my LS6 intake )
Old Dec 18, 2007 | 02:25 PM
tada....
https://ls1tech.com/forums/showthrea...753&highlight=
Old Dec 18, 2007 | 02:28 PM
chpmnsws6's Avatar
This is what i'm looking for.
I was just about to give you your old link haha
When I looked it up, it said "connector" like maybe it was the pigtail connector?
Old Dec 18, 2007 | 02:30 PM
yep, thats them,,(actually, mine looked a tad bit differnt than that) except when i bought mine,,you could not just buy that clip,,it was the whole connector.
Old Dec 18, 2007 | 02:31 PM
duh,,i just reread the first post,,,,yes, the LS1 clips are different than the ones pictured up above this post..
Old Dec 18, 2007 | 02:37 PM
i found a pic,,but its in an email and it wont copy/paste into here...looks more like a bent paper clip than the flat metal on those....
Old Dec 18, 2007 | 03:18 PM
chpmnsws6's Avatar
Found two of them! Just need one more haha
Old Dec 18, 2007 | 03:20 PM
chpmnsws6's Avatar
Those are for the Pigtail. You don't need to remove those to pull the plug. You push them toward the plug and pull the plug. There is a small "hill" on the plug that the wire rides up.
I'm looking for the clip that holds the injector to the rail
Old Dec 18, 2007 | 04:15 PM
chpmnsws6's Avatar
Found the last one! haha
Thanks for the help guys. I'd still like to know the part number for future LS1tech reference.
Old Dec 18, 2007 | 04:38 PM
98Camarod's Avatar
I don't have any of them hooked on. I had them on and I didn't like the way the bottom was sealing with the new injectors. I unhooked them and they seat fine and do not leak.
Old Dec 18, 2007 | 04:43 PM
chpmnsws6's Avatar
With the for of 60psi behind them, I do not want to risk an under hood fire.
Old Dec 18, 2007 | 05:05 PM
98Camarod's Avatar
The rail is not going any where. What about the aftermarket rails, the injectors are not held in by clips either.
Old Dec 18, 2007 | 05:17 PM
1999ssls1's Avatar
I have a whole set if anyone needs them....
Old Dec 18, 2007 | 05:20 PM
99_Z_155's Avatar
Those clips are not serviced by GM. I just looked in the catalog.
Old Dec 18, 2007 | 07:28 PM
chpmnsws6's Avatar
This is why i didn't have them. I pulled my aftermarket rails off. The aftermarket rails have longer "bores" in them.
If GM can't even get them, how are they replaced? Or do they only come with a new set of injectors?
