need info a.s.a.p. if cam parts are compatible with ls1!!!
i have a friend who is selling everything for a valve train upgrade all crane cam's brand for $500 but he got it for a 80 something iroc 350 chevy motor how do i know if this stuff is compatible with the ls1 and do you guy's think its a good deal? parts are a .510 lift cam, hardnd pushrods, valvesprings, roller rockers, lifters, dbl. roller timing chane... dont know if i'm forgeting something i would need, am i? everything is new in box!
The only thing that could work would be the valve springs, but SBC (old 350s) usually use very low lift copmpared to LS1, so those springs may only work on a stock cam. The LS1 only has the bore spacing the same as an SBC, everything else is totally different and nothing is interchanble.
none of it will work. stock rocker ratio on the old sb is 1.5 stock for ls1 is 1.7
good deal prob if you had a old school 350 but you can make way more power with the ls1
for less.
for less.
