Ms3 and nitrous?
Old Dec 22, 2007 | 06:16 PM
02c6ss's Avatar
Default Ms3 and nitrous?
Do any of you know if the work well with each other?? I will be shooting 175-200 to the car. Let me know what cams yall would use for a stock longblock nitrous engine.
Old Dec 22, 2007 | 06:52 PM
DVS99TRANS's Avatar
From what I've seen, yes they do and pretty damn well. A fella on here (termin8r) had the same set up and had tons of videoes of him rolling on with some 2.2 KB Cobras, Ford GT, and some really powerful cars and pulling from them all. He made mid 400 at the wheel and something like 650 on the bottle. Been a while since I've seen them. I am planning the same thing but don't know how long the stock rotating assembly will last with it. I'm personally going to wait to spray mine until I get a forged block to handle a bottle on top of the MS3. I know the stock block can handle a little over 500 at the wheel naturally aspirated. I think the pistons and rods won't be able to handle it for very long at all IMHO.
Old Dec 22, 2007 | 07:39 PM
02c6ss's Avatar
Im just gonna put rod bolts in it and cross my fingers!!
Old Dec 22, 2007 | 08:22 PM
caMnaro's Avatar
I am going to be spraying this summer,will let you guys know how it goes.Probably only a 150 shot.
Old Dec 22, 2007 | 08:29 PM
02c6ss's Avatar
How do you like the ms3?
Old Dec 22, 2007 | 08:43 PM
caMnaro's Avatar
i did not have a full dynotune,but had what me and friends did w/hp tuners and it did not buck that bad.It was 6 speed so that helped but it would surge sometimes at like 1400-1600 rpm and that was it.i liked it a lot and it pulled like a monster in the higher rpm.i am planning on having epp tune it this summer for spray and the automatic.
Old Dec 22, 2007 | 10:13 PM
OneMean01's Avatar
I have a buddy of mine that has the MS3 cam on a stock LS2 with a 90/90 intake and a 150 wet shot. His car is damn fast for just a cam intake car. I had a LS1 with heads cam and intake and would pull maybe a car on motor on spray to spray it was a dead even match with me on a 100 shot but i had very high compression. He has a killer car in the Amarillo area and put down a lot of cars with his set up. It is also his everyday vehicle and he loves it.
Old Dec 22, 2007 | 10:16 PM
GMmexican's Avatar
termin8r was using a 200shot most of the time and he claims his car lasted him 2 years with a dozen dyno pulls and refilling his bottle every weekend.....
Old Dec 22, 2007 | 10:19 PM
LS1SpeedAddict's Avatar
They work very well together . I'm not sure what your goals are but I went 10.24 on a 125shot with the MS3, TSP 5.3 heads, and nitro daves plate. Going for 9s in 08 on the stock bottom end.
Old Dec 22, 2007 | 10:39 PM
caMnaro's Avatar
Thats what i want to hear.my limiting factor will be the rear end.the new trans converter will hold it all.
Old Dec 22, 2007 | 11:04 PM
02c6ss's Avatar
Thanks for all the replies!!! Im def getting this cam!! What convertor do yall suggest? I was looking at a 3600 fuddle since this is my only ride
Old Dec 23, 2007 | 08:36 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I hit my MS3/PRC headed TA with a 150 shot and it loved it
Old Dec 23, 2007 | 08:46 AM
sedanman's Avatar
I plan to spray my MS3 car this spring. What was your MPH? Any weight reduction? Did you have to fly cut the pistons for those heads?
Old Dec 23, 2007 | 08:47 AM
sedanman's Avatar
Power and track numbers?
Old Dec 23, 2007 | 04:06 PM
My best MPH was 132 and the only weight reductions was removing the A/C, tearing the backing off the stock carpet, removing passenger air bag, spare tire and jack. Other then that I'm pretty much full weight, I still have the back seats in my car. Adding the 8pt kinda balanced out the weight reductions so I'm probably around 3600-3700. I did not have to fly cut the pistons but I did have Texas speed recess the valves in my heads a little bit so I would get some added clearance.
Old Dec 23, 2007 | 06:02 PM
Z28/2002's Avatar
Don't really know the power numbers but i went 11.15 @ 129 with a very soft launch and short shifting the car. The 60 ft was a 1.91. My TA was full weight and still had 3.42s. It was an easy 10.5x car with some gear but it broke before I had a chance to make an all out pass
Old Dec 23, 2007 | 06:26 PM
GM Muscle's Avatar
Cam works pretty well with nitrous. I had my car walking easy 10.50s at 130+ with the MS3 and a 150 shot. Adding a 50 dry on top of that it was going consistant 10.1. Race wieght was low 3K at the time. Hopefully it'll crack a 9 in the spring with the stock shortblock and stock heads.
Old Dec 23, 2007 | 10:29 PM
Kenny H's Avatar
Thats an excellent combo. I good friend of mine has that combo (150 wet shot) and has went 10.5 @ ~ 130 MPH at full weight with crappy stock '98 heads. He pulled off of a whippled Cobra pretty convincingly a few weeks back from a roll.
Check it out about 55 seconds in. The camera view is from inside the Cobra.
http://www.youtube.com/watch?v=-mGsxxvjarw
The SS driver hits 3rd and pulls a bit and his 3-4 shift is about as good as it gets at the 1:07 mark and he steadily pulls away. I'm not sure exact how strong that Cobra is but obviously the SS gets in done convincinly.
Old Dec 23, 2007 | 11:00 PM
DVS99TRANS's Avatar
What LSA does everyone have??? I got a 114 and wish I should have possibly gone a bit lower but oh well. It will still make great power. Can't wait to have this setup done this season, finally have the money for it
Old Dec 24, 2007 | 05:52 AM
Z28/2002's Avatar
Mine is on a 113
