Am I missing anything? (head/cam swap)
Hey guys,
Just curious if I was missing anything to get my head/cam swap completed. Can you just take a look at my list and let me know. Thanks!
PRC Stg 2.5 5.3 heads complete
Chromoly Hardened Pushrods
Melling High Volume Oil Pump
TR224 Cam
LS2 Timing Chain
LS7 lifters
GM Head/Cam swap gasket and bolt kit
LS6 Intake
Pacesetter LT's
TSP Catted Y
Thanks again for your help
TR224 Cam
LS2 Timing Chain
LS7 lifters
LS6 Intake
Pacesetter LT's
TSP Catted Y
You didn't say what car/year/motor in your post or sig.
While it's apart it's not a bad idea to replace the lifter trays, they are pretty cheap (Ls1/LS6 version):
http://www.sdparts.com/product/12551...ideLS1LS6.aspx
If you have some miles on the car I would replace the cam retainer plate because it comes with a new lifter galley gasket (this will require the new style retainer plate bolts as well). I also replaced the cam gear, the new LS2 version has some small improvements.
You should also get a new O ring for the oil pump pickup.
Digital camera. Taking pictures during disassembly helps getting hoses and wiring harnesses back exactly where they came from during reassembly. Using ziplock bags with labels so you can group different fasteners as they are removed helps when it's time to put things back together. You just grab the zip bag and all the fasteners for a particular item are right there.
Get new lifter trays, cheap insurance and some of the ones that are marked "10" had issues.
Don't follow LS1howto to remove or install the pulley. Use a socket to press the original pulley off (not the bolt) and then make or buy a tool to press the pulley back on. Consider pinning the crank.
I went to Ace hardware and bought a 1" longer bolt with the same thread as the crank bolt...it brought the pully on slicker than sex. Once I got it started about an inch I switched to the new crank bolt at was done!! It was a $5 bolt, but worth every penny.
Thanks for all the helpful hints! Are the lifter trays really that necessary? I was hoping to knock this out this coming weekend, but I doubt I can get the parts here that soon. Anyone know where I can buy them? I know SDPC has them but I don't know if I can 2nd day them. Anyone know?
Thanks
Thanks
