Is this Cam Too Aggressive?
Old Jan 2, 2008 | 08:28 PM
kingsofstreet's Avatar
Post Is this Cam Too Aggressive?
For my Daily Driver, 02 LS1 Z28, with full exhuast, 3000 stall converter
A4 Trans.. Not worried bout mpg's just wanna know is this cam is too aggressive for a "going to work car" Oh and I will probly hook a small wet kit up eventually...
Is this Futral Cam over the top or Just right in your opinion???
Opinions/Theory/Explain.... THANKS
FMS Custom Grind Camshaft - 228"/230" .576"/.595" 112LSA - aggressive profile with a 2200-6600 RPM range, fair idle
Old Jan 2, 2008 | 08:31 PM
1badA3Z's Avatar
I ran a tsp cam that was alot bigger in my ride around car,and it worked great.You shouldnt have a prob with it!
Old Jan 2, 2008 | 08:35 PM
tacklebox's Avatar
Dude i just posted an idle clip of a very similar cam mine is a 228/230 .588/.592 lift on a 112 lsa. this is untuned right after 1st startup:
http://videos.streetfire.net/video/9...17015ce60b.htm
Old Jan 2, 2008 | 08:57 PM
That sounds sick!!!!, Thanks for that clip bro.
Old Jan 2, 2008 | 09:17 PM
Mazzenger's Avatar
I dont think it will be too aggressive for at all.
Old Jan 2, 2008 | 09:41 PM
madclown's Avatar
no problem at all.
Old Jan 2, 2008 | 09:47 PM
Damian's Avatar
LSX Mechanic
That cam is actually very docile, especially by today's standards.
Any of Futral's 230ish cams are a win. All make great "big cam" power, but have "small cam" driveability. I'll never recommend anything other than Futral cams to my customers.
Old Jan 3, 2008 | 08:51 AM
bowe1632's Avatar
yea man that cam will be good for ya.....the f13 is a little bigger and its fine with me right now http://www.youtube.com/watch?v=tskKVcOuApQ
Old Jan 3, 2008 | 10:25 AM
plaf713's Avatar
you'll be just fine after a tune, and that stall will help you out with driveability as well. that'll make some good power as well, i just bought a cam 228/232 dont expect to have any problems with it.
Old Jan 3, 2008 | 10:41 AM
rickyracer25's Avatar
you'll be just fine
Old Jan 3, 2008 | 10:52 AM
1970judge's Avatar
228/230 cam is a good mid range cam. Idle quality isn't too wild. It is cut on a 112 so it is a little rough but nothing major. Sounds like a great cam for your setup man. Tuned properly the cam will make great power.
-Marcus
Old Jan 3, 2008 | 11:00 AM
liquidsmooth's Avatar
when you got close to the motor i heard a ticking... i have that same tick, is that common and nothign to worry about? Listen at the very end
Old Jan 3, 2008 | 11:04 AM
Default thanks
Thanks for the helpful feedback
My order is placed!
I'll be sure to post some video results once complete.
Thanks again.
Old Jan 3, 2008 | 11:20 AM
plaf713's Avatar
yes there is usually a lot more valvetrain noise after doing a cam swap
Old Jan 3, 2008 | 11:32 AM
1970judge's Avatar
Dual springs are usually a little louder. If the noise isn't anything too terribly loud, i would not be worried. That cam as mentioned is very docile, considering the cams we have on the street out of our shop. Some small, some BIG.
-Marcus
Old Feb 9, 2008 | 09:58 PM
Unhappy update
got my cam, springs, converter, gears. There sitting in my closet and will stay there a while..... Don't have the dough for installation ATM. A bit discouraged but will get it done eventually. Thanks again for all the help.
Old Feb 11, 2008 | 04:57 PM
Camaro396's Avatar
Damn that thing sounds good.
Old Feb 11, 2008 | 05:59 PM
JPH's Avatar
JPH
I would like to see a little more convertor myself, but all n all cam is a great grind.
