Pushrod Length
Old Jul 1, 2003 | 10:51 PM
silver02ws6's Avatar
Default Pushrod Length
i have a hotcam in my car and heads that are milled .035. Do i need the stock pushrods or do i need to go with a 7.35 pushrod.
Thanks
Old Jul 2, 2003 | 01:05 PM
Default Re: Pushrod Length
you mean to tell me that no one on this whole board knows the answer to my question. You know im really just blank as to why i can never get a response on this damn board. I normaly dont post over here for that simple fact. Guess you all just dont care if the post count is under 3000
Old Jul 2, 2003 | 01:36 PM
BIG PD's Avatar
i don't know the lift of your cam but i assume it isn't over .580. stay with the 7.4's
Old Jul 2, 2003 | 01:40 PM
SS3520's Avatar
If your heads are milled I don't think you need to be running the stock length pushrods. I would ask who did the heads what size they recommend for that setup. Or you can measure whats in the car already.
Old Jul 2, 2003 | 03:23 PM
Tin Indian's Avatar
Hey...Lighten up..... Sometimes you might just have to wait more than 2 hours. Give it a little time.
Use stock 7.40" rods.
Old Jul 2, 2003 | 03:26 PM
Vents's Avatar
for a/m cams and milled heads (up to .040), the p-rod geometry is pretty close to stock. a 7.4 is fine.
Old Jul 4, 2003 | 09:30 PM
I wasnt trying to be rude or anything but in most cases when i post somthing over here it seems like a get someone either telling me to go do a search wich i done before posting or i get no reply at all.
Old Jul 4, 2003 | 09:47 PM
Slowhawk's Avatar
LS1Tech Sponsor
I would try the stock pushrod first and do the how many turns for preload test.I put on LS6 heads shaved .030 and running a TR224 Cam and used 7.350 pushrods because 7.40's were too long.
Old Jul 5, 2003 | 04:41 AM
redz_02's Avatar
vince, all up in the geometry.
