yella's on a 98?? worth it?
Old Jul 2, 2003 | 08:53 AM
98sspullin'em's Avatar
Default yella's on a 98?? worth it?
is it worth putting yella's on a 98 since you have to grind them?or could you get the centerbolt valve covers from 99 up? or would that even work? and just wondering if its worth the trouble?? thanks
Old Jul 2, 2003 | 09:19 AM
StevieZ's Avatar
Default Re: yella's on a 98?? worth it?
Grinding will take about 1 hr. if you have a good aluminuim bit and an air tool. Well worth it.
Old Jul 2, 2003 | 09:21 AM
YIKESS's Avatar
you cant use 99 valve covers on a 98 head.....You should have to switch the heads then.
Old Jul 2, 2003 | 04:44 PM
Z28_HESS's Avatar
Where can you get new valve cover's with the center bolts.....and how much are they???
Warren
Old Jul 2, 2003 | 04:57 PM
2001CamaroGuy's Avatar
Warren
you have to change the heads to use the 99 and up center bolt covers.....the 98 heads won't work with them....
Old Jul 2, 2003 | 05:28 PM
Cal's Avatar
Cal
Just do the grinding; someone posted a picture a week or so ago that showed exactly where you need to do the grinding.
Old Jul 2, 2003 | 09:21 PM
Do you happen to remember the thread name or anything so i can find the pic?? I saw some centerbolts on parts for sale.... Thanks
Old Jul 3, 2003 | 06:30 AM
StevieZ's Avatar
Here you go......
