Will this be a close one??? Pred-z, Patrick-g??
Old 01-17-2008, 08:27 PM
crazylane's Avatar
Default Will this be a close one??? Pred-z, Patrick-g??
I was told that with this cam
230/232 .615/.595 XFI/XE-R On a 111+2
And these heads
TEA 2.5 5.3 63cc.
That I would have to fly cut.
Is this true. Does anybody have any experince with this combo, or close to it?
Old 01-18-2008, 10:51 AM
crazylane's Avatar
No body at all huh??? Jeeze...
Old 01-18-2008, 11:11 AM
Flow Wizard
Tony Mamo @ AFR's Avatar
Yes....it will be tight.
It all depends on how much clearance you feel is enough.
It will certainly be a fair amount less than the textbook .080/.100 minimum.
Fly cutting would be a good idea to have additional peace of mind. The LSA is the deal breaker for you IMO
Tony
Old 01-18-2008, 11:13 AM
crazylane's Avatar
Allrighty then, I guess I will order me a set of fly cutters.
thanks
Old 01-18-2008, 11:36 AM
JPH
JPH's Avatar
thanks
check before cutting. you can always rent one from a sponsor or member for alot less.
Old 01-18-2008, 11:41 AM
chrs1313's Avatar
with my cam 230/230 .612 .590 on a 111+2 i had .085 on the intake valve and around .125 on the exhaust...this is with stock heads 241s and stock gaskets...
when it was on a 111+4 it was a little to close for me with the intake at .072 and exhaust .140...so i retarded it 2 degrees to 111+2...hope this helps
Old 01-18-2008, 11:48 AM
crazylane's Avatar
My cam has .003 more lift than yours, and my heads are 63cc, With OEM Head gaskets. What are the stockers?? 64cc??
Well if anything, I will do like you and retard the cam 2 degrees, and that will put me at 111 straight up. And then measure form there, and see were I sit.
And hey, what clay did you guys use for checking, Did you just buy some at a hardware store or something?
How long does it take for them to get here, if I was to rent them???? JPH???
Old 01-18-2008, 12:13 PM
NassyVette's Avatar
You can get modeling clay at your local hobby store.
Old 01-18-2008, 12:18 PM
crazylane's Avatar
Thanks man, I appriciate it.
Old 01-18-2008, 02:35 PM
crazylane's Avatar
This was straight from Mike@TEA.
With a 5.3 head assume anything over 228 will not fit until it is checked to make sure. I cannot tell you to go ahead and run that and it will be okay because I have seen 232 cams crash!-Mike
So I guess I will be flycutting. Just to be safe.
Old 01-18-2008, 02:45 PM
Asmodeus's Avatar
Since you're going to flycut (which isn't that big of a deal anyway) go ahead and run a .040 gasket and bump your compression, just flycut a little deeper.
Old 01-18-2008, 03:17 PM
Trev_SS's Avatar
I would go ahead and flycut just for safety reason and run a cometec gaskit with .040 size. JMO!
Old 01-18-2008, 03:19 PM
NassyVette's Avatar
I'm in pretty much the same boat as you now. I'm gunna be running a T2 with 60cc TEA 5.3's and .040 cometic gaskets. If you're flycutting anyway, you might wanna think about milling the heads to bump the compression. I calculated mine right at 11.5:1 SCR.
Old 01-18-2008, 03:30 PM
crazylane's Avatar
If I was to mill any more. Like down to a 61cc. Will I still be able to run 92 octane???
I was thinking the same, if I am to fly cut, might as well run the cometics.
With the .040 Cometics, and I mill it to 61cc, what would that bring my CR up too??
Old 01-18-2008, 03:41 PM
NassyVette's Avatar
A 61cc head will bring you to roughly 11.3:1 SCR and 8.6:1 DCR, and with a .040 cometic your quench should be about .034 which is tight enough to get away with that compression ratio. (tighter quench = less chance for detonation)
Old 01-18-2008, 03:42 PM
crazylane's Avatar
So 92 oct should be good? As long as its good gas. lol
Old 01-18-2008, 03:46 PM
NassyVette's Avatar
It depends on the tune as well, you'll need a good tune, tight quench, and quality gas. Cover those bases and you should be good. Just FYI with the 63cc heads you would be at 11:1.
Old 01-18-2008, 04:26 PM
crazylane's Avatar
I would be at 11:1 with 63cc and .040 Cometics???
Thats still not to bad. I may just do that. Instead of spending the extra on getting them milled. And hoping my tuner can tune it good enough to run 92 with no additive..
I can't wait till I get this going, I think its going to be a pretty nice set up.
I will run my LS6 for now, and later down the road put either a 90/90 set up, or the new Mani thats coming out from Wieand
Old 01-18-2008, 04:46 PM
NassyVette's Avatar
Yup, those a definitely some kick *** heads, should be a really nice combo. Whatever you end up doing, good luck with it.
Old 01-18-2008, 04:49 PM
crazylane's Avatar
Thanks man, I appreciate your help. I will make a thread up when I start the build up. So keep an eye out..
