Ls2 timing set vs double adjustable set?
Old Jan 20, 2008 | 10:28 AM
wilwhite2kss's Avatar
Default Ls2 timing set vs double adjustable set?
what benifits would come of getting a double roller adjustable timing set as apposed to the ls2 set, or would it just be a wast of money for either and stick with the ls2 timing chain only( not the set)? BTW this is for a cam only install
Old Jan 20, 2008 | 10:33 AM
jkwalkercchs's Avatar
if your only doing a cam i say u dont need it
but if u have the money go ahead and change it cause u will get the itch and start upgrading once u feel the power
Old Jan 20, 2008 | 10:47 AM
405HP_Z06's Avatar
Personally, I'm not a fan of double roller chain sets, I prefer a nice single set. As far as adjustability, that would depend on what you wanted to do. If the cam is ground correctly AND you don't want to vary the cam timing than an adjustable set is NOT required.
The LS2 chain is a very cost effective option for a good chain if you choose to go that direction.
Old Jan 20, 2008 | 11:00 AM
massls1guy's Avatar
I just replaced the chain with the LS2 version, it doesn't cost much and it's much stronger looking than the original.
If you decide to go double roller do some homework and search on it. Sometimes you have to grind down your front cover to get the thicker double roller sprockets to fit.
Old Jan 20, 2008 | 11:01 AM
vettenuts's Avatar
I like a good single chain as well. I have read of too many guys having problems fitting in the double. I think the way to go is a good single setup, the GMPP timing chain damper, and hopefully a Torrington bearing on the cam gear. A few guys have broke double chains, and I tend to think when they install they don't verify the sprocket alignment with a straight edge.
Old Jan 20, 2008 | 11:07 AM
blksheep's Avatar
i personally like the double. I feel better with it, then having the "bicycle chain"
Old Jan 20, 2008 | 11:49 AM
RZRSEDGE's Avatar
I like the Cloye's Hex-Adjust. Strength, adjustablity, and still a single row. I think you can get a double also.
Old Jan 20, 2008 | 01:32 PM
chrs1313's Avatar
i would recommend an adjustable if you are getting a custom cam because you might wanna get a little more clearance by either advancing it or retarding it...but if it is an off the shelf gauranteed fit go with the ls2 timing set, dont just replace the chain...
Old Jan 20, 2008 | 02:50 PM
405HP_Z06's Avatar
Originally Posted by chrs1313
.......because you might wanna get a little more clearance by either advancing it or retarding it
If you need PTV clearance, flycut.
... dont just replace the chain...
What's the benefit of replacing the stock timing gears with the LS2 gears, assuming the stock gears are in acceptable mechanical condition? The LS2 gears are made of the same material as the LS1/6, they are manufactured different to accommodate the sensor changes in the LS2.
Old Jan 20, 2008 | 04:16 PM
Shawn @ VA Speed's Avatar
ls2 chain works great
Old Jan 20, 2008 | 05:04 PM
Thank you all for your advice guys. If its not gonna make a difference , and make my cam install more complicated, then i think i will just do the ls2 chain only.
Old Jan 20, 2008 | 05:33 PM
vettenuts's Avatar
Just chain only will eliminate any issues with sprocket alignment as well with a new setup.
Old Jan 21, 2008 | 03:30 AM
chrs1313's Avatar
[QUOTE=405HP_Z06;8531759]If you need PTV clearance, flycut.
QUOTE]
Yeah because flycutting is just so much fun and easy to do over advancing retarding the timing...
also i know lots of people just change the chain but wouldnt u just want piece of mind to have sprockets that were actually made for an ls2 chain...even if it looks ok i bet it isnt a 100 percent perfect fit...those sprockets are made for ls1 chains...to each his own...
Old Jan 21, 2008 | 06:07 AM
Randy WS6's Avatar
I have the LS2 double roller and it fit perfect ,no clearance issue at all + its 8 way adjustable.
Old Jan 21, 2008 | 07:02 AM
vettenuts's Avatar
Further information on the JWIS timing chain. I sent an e-mail to IWIS Ketten about the JWIS chain (sold by Katech as the C5R chain). Here is a quote from the response I received:
"The roller chain G68V-2 is one of our best 3/8" roller chains and has typical iwis features for example the seam in the rollers. For your information the G68V-2 is the series chain for the BMW M V10-Engine and its appropriate for high numbers of revolutions.
Old Jan 21, 2008 | 10:07 AM
405HP_Z06's Avatar
Nice work, looks like the Katech chain is a winner!
Old Jan 21, 2008 | 09:29 PM
smokeyrider05's Avatar
ls2 cheap and just as good in my opinion.
Old Jan 21, 2008 | 10:09 PM
RooRnZ28's Avatar
swapped out my double roller for the LS2...... so far so good!
Old Jan 21, 2008 | 11:13 PM
65SSZO6's Avatar
I too am in want of a replacement timing set,mine is for a 2004 LQ4. My Chevy dealer will sell me the LS2 for $100, but I was looking at SDPC they have a RollMaster Double Roller with Torrington bearind and oil pump spacer for $114.That sounds like a steal? Has anyone used this T-set in a LQ4 any issues?
http://www.sdparts.com/product/SDCS1...onBearing.aspx
Old Jan 22, 2008 | 12:05 AM
99mongooSS's Avatar
go double you will thank yourself later
