Problem found( Damaged reluctor Wheel)
Old Jan 21, 2008 | 04:37 PM
01 BERGER CAMARO SS's Avatar
Default Problem found( Damaged reluctor Wheel)
After 2 months of trying to find out what was wrong with my car. It turned out to be the reluctor wheel. One of the teethe was bent so bad that it was bent far enough that the crank sensor couldnt read it. It kept throwing out the crank sensor code NOw the big question
CAN I JUST BEND THE TOOTH BACK TO ITS PROPER POSITION AND PUT MY CAR BACK TOGETHER? I ALREADY HAVE AND HAVE CHECK THE WHEELS SPACING AND EVERYTHING CHECKS OUT. WHAT YOU GUYS THINK
Old Jan 21, 2008 | 08:13 PM
Grimes's Avatar
I say go for broke! I think you will be fine if you just bent it back perfectly.
Old Jan 21, 2008 | 08:18 PM
BLACK2001SS's Avatar
Yeah its up to you I just wonder why it bent in the first place. Good luck if it were me I'd probly just bend it back haha.
Old Jan 21, 2008 | 08:49 PM
Yea, im with you guys. The motor didnt tick and oil pressure was perfect. Only the friggin reluctor wheel. I bent it back into place and looks fine. Ima put her back to gether tommorow
Old Jan 21, 2008 | 09:26 PM
Randy WS6's Avatar
I would heat it up to bend it back , because its pritty hard metal ,dont hit it with a hammer or any thing it will deform it,Heat it up and bend it back with a pair of pliers
Old Jan 22, 2008 | 11:15 AM
eallanboggs's Avatar
If there are any burrs on that tooth I'd file or sand them off.
Old Jan 22, 2008 | 11:25 AM
Eric95's Avatar
what could cause a bent tooth on the reluctor wheel?
Old Jan 22, 2008 | 11:47 AM
was probably nicked or bent during assembly or machining
