So I just started my car, after H/C/I underdrive pully install....
Old 01-27-2008, 11:43 PM
geovett's Avatar
Originally Posted by twizted_creations
Alright guys, I just started my car after a heads cam install. Anyway... first try it didnt even do a full revolution, and it fired right up... let it run for a few minutes... great oil pressure, charging... everything was gravy... Shut it off, checked the fluids, and when I started it again, it was surging like a bitch, and didnt want to run on its own.. Like as soon as the lifters pumped up... Normal? Havent put any miles on her yet, and am hoping that the puter needs time to think about what happened.
what type?,size of underpulley did u use, man i'm starting my h/c install ... but i'm NOT going to tackle it..........lol. 01SSA4.....thx
Old 01-28-2008, 12:00 AM
99mongooSS's Avatar
go to speed inc then.
Old 01-28-2008, 12:47 PM
cdoggy81's Avatar
Good to hear you got it all fired up & going well. When you tune it you will be very happy!
"Trans Go is a shift reprogramming kit. Unless you are very patient and mechanically inclined, I would let a trans shop do it... We got lucky."
so it's a mechanical shift kit like you used to put in the old TH400
I was going to get the car re-tuned which improves the shifts & the shift points. Is this what the Trans Go mod does or does it help in addition?
Old 01-28-2008, 03:34 PM
twizted_creations's Avatar
Yeah, but its actually ALOT more than the old school shift kits, it involves pulling the valves for gears and replacing a shitload of springs and valves. If you do this I would suggest contacting FLT and getting all the replacement billet pistons, and the composite checkballs as well with the kit....
Old 01-28-2008, 03:35 PM
I would suggest the same as above. Get a set of heads from speed inc, and you will not be dissapointed.
Old 01-28-2008, 10:39 PM
BlackZ28629's Avatar
once you get a tune, your idle will be better. Remember, you are putting a lot more air into the engine and getting rid of a lot more, as well. This changes the speed or rate at which these happen and your idle is not going to learn itself. Computers have to be told what to do Try drilling a hole in your throttle body butterfly (small, small one) and that will help if you can't get to the tuner soon. Good luck and congrats on the install!
