Today Sucks the BIG ONE!
Old Jan 28, 2008 | 01:06 AM
little Red Camaro's Avatar
Default Today Sucks the BIG ONE!
Bought new H/C package for 98 TA. Started the teardown and noticed my motor needs new cam bearings , so next step was to totaly tear down the motor to have the new bearing put in, then what do I find next...#3 rod is bent , Man life sucks. The motor came out of a 2000 Camaro SS with 50,000 so I was told, also was told motor ran perfect. Oh well atleast I know what I got know!
Old Jan 28, 2008 | 01:09 AM
SSMOKIN_Y2KSS's Avatar
that sucks man im sorry..i feel your pain
Old Jan 28, 2008 | 07:04 AM
06PIMPALASS's Avatar
Been there!Bummer!!!!!!!
Old Jan 28, 2008 | 08:03 AM
s346k's Avatar
i bought a running 6.0 with no intentions of machinework...well, it went from a stock bottom 6.0 with L92 heads to a 13:1 comp. 374 with forged rods and pistons haha.
good things may come from this, just wait.
Old Jan 28, 2008 | 10:42 AM
ssduane's Avatar
Its better you found the rod this way then with it stuck through the side of the block.
Good luck.
Old Jan 28, 2008 | 10:59 AM
AINT SKEERED's Avatar
I just bought a Nova that had a 396 big block supposed to be fresh with good rods , pistons and steel crank. The heads were supposed to be rectangle port . Motor is slap wore out with 70% leak down in 1 cyl 50% in 4 cyl and the other 2 had 20 %.
Pulled the motor down and its a 2 bolt main instead of 4, oval passenger car heads with 2.08 valves which are very small for a big block and cast pistons , stock rods and cast crank.
The good side is I got a 6.0 lq9 with very little time on it from a freindly machine shop for a helll of a lot cheaper then I could have built the big block for.
It sucks to hear none the less
Old Jan 28, 2008 | 11:10 AM
Sharpe's Avatar
Man, this makes me scared to buy a "low-miles, runs great" motor now. Was looking at a 25,000-mile LS2 longblock (minus rockers and covers).
Old Jan 28, 2008 | 06:39 PM
Just be careful, and try to get it cheap...or hear it in the car!
Old Jan 28, 2008 | 08:01 PM
Hell man we just installed a 2.7 Piece of **** Chrysler V6 at work.Same story from salvage yard,Low miles,Runs good.It's oiling down the #1 plug and smoking obviously!We should have pulled the plugs but we have bought used motors from these folks before so................Now if any of you know the labor involved it is quite a bit.Yeah they will give us another one but WTF!!!!!!!
Old Jan 28, 2008 | 08:04 PM
Apollo0526's Avatar
That sucks dude. Better now than later, maybe when your done it wont be a 350 anymore......
Old Jan 28, 2008 | 08:11 PM
01 BERGER CAMARO SS's Avatar
been there done that. It freaking suxs when **** goes wrong. Fawk it rebuild it with good pistons, rod bolts and main studs. Peace of mind.
Old Jan 28, 2008 | 08:29 PM
^^^^^^^^^^^Yea probaly will go that route!^^^^^^^^^^
A friend of mine gave me a couple of his rods to replace my bent one. Just running low on the funds to go all forged, and my wife is sick of me spending money on this car. Dropped block, crank and rotating assembly of to a local shop to get an estimate on fixing my problem. I was able to get the guy that sold me the motor to pay for half of the repair cost eventhough he really didn't want to. He told me he has been in this business for 30 years and never once went back to the seller to ask for help with repairs on a bad motor he bought.
Old Jan 28, 2008 | 08:52 PM
zman1969's Avatar
Default 2.7l POS
the 2.7l is SO BAD that used are almost as much as used and they're all sludged up too -throw away car!
Old Jan 29, 2008 | 06:56 AM
SS101's Avatar
this will probably turn out to be a blessing in disgiuse...finding a bent rod in the block and getting that fixed is costly, but it doesnt hold a candle to finding a bent rod THRU the block and fixing that lol
Old Jan 29, 2008 | 11:07 AM
qwk93ta's Avatar
Well stated......
Old Jan 29, 2008 | 01:47 PM
flip888's Avatar
Your lucky, most people wouldnt even bother. At least thats the way its been for me.
Old Jan 29, 2008 | 03:06 PM
Cole Train's Avatar
i had that happen to me dude only the rod went thru the block It was on my '00 GTP. i chipped the #3 piston (KR cause) and replaced with a "low mile" engine from a local yard. Put it in with new headgaskets and she started right up. Drove it a day and went to work one day. Got there and sounded like it was ticking a little. Thought maybe it was in my head or i was being paranoid. Drove home that night and was about 3-4 miles from home and it was starting to knock HARDCORE. So i figured since i knew i was gonna have to pull the motor again anyway that i might as well keep going. Haha made it another mile MAYBE and she was making all kinds of noises and siezed, DEAD. i had my LS1m Palm scanner on it at the time and was getting spikes of 13+ degrees or knock retard at cruise at 1800 RPM's. Pulled it off the road and looked under it with my cell phone light and there was oil coming out from under. Pulled it to my house and looked under it and threw a rod through the oil pan, another through the block and the crank was TOAST. Checked the heads and they amazingly survived the melt down. So i went back and they refunded me my money and i rebuilt the original engine. New owner hasn't had a problem with it since he bought it 2 years ago and i'm sure it's over 200k miles now. Man i feel your pain~Cole~
Old Jan 29, 2008 | 04:56 PM
pwrtrip75's Avatar
Thats why I try to explain to people engines do not travel miles. Miles means nothing on an engine. Its all in what it has been through....nothing else. The 5.3L in my nova is a 100k+ junk yard engine....still an untouched shortblock seeing 15 psi of boost all summer with out an issue.
Old Jan 30, 2008 | 06:46 PM
yes it was a blessing,my bank account doesn't see it that way, but I am having the motor rebuilt with all forged internals. Figured makes sense seeking everything on top is new. Plus I can put a little squeeze on it and have no worries!
