Wasn't a spun bearing after all...
To make a long stupid story short; I pulled the motor 99% of the way out of my car thinking I had a spun bearing and it turned out to be loose converter bolts.
It has 107k on it so I might as well refresh it while it's out. What all do I need to buy? I cant afford forged pistons and rods right now. So far I've thought of:
-ARP bolts
-Main and rod bearings- Any particular brand?
-Rings- Any particular brand?
-Timing Chain
-Gaskets
I'll probably through a cam in it but everything else should be ok left stock right?
-ARP bolts
-Timing Chain
-Gaskets
-ARP bolts
-Timing Chain
-Gaskets
-ARP bolts
-Timing Chain
-Gaskets
Oil pump
lifters
Might as well have the heads rebuilt while you're @ it
Weber stage 1 6.0L
What if I were able to scrape together $2,999.00 and buy this Weber short block? If I used everything I possibly could from my LS1 what could it cost me above and beyond the price of the short block?
http://weberracing.net/Engine-Type-G...duct_info.html
