Remove a Camaro SS 00 LS1 Engine from Top or Bottom ???
Old Feb 3, 2008 | 11:49 AM
hammertime's Avatar
Originally Posted by ae13291
dammm i bet your pretty fast at removing the engine on f bodys now!!
I've heard dealer techs say you can have it out the bottom in as little as two hours. Of course they are using a two post lift...
I'm also curious how long it is taking 1BADAIR, especially since he has a few under his belt now.
Old Feb 3, 2008 | 11:56 AM
LS1Silverado05's Avatar
+1 LOL..Damn....This guy has been busy..
Old Feb 3, 2008 | 11:59 AM
styoung's Avatar
maybe this will help you
http://www.michiganspeed.com/enginepull/index.html
http://ken.lowrance.com/Projects/Hea...ineRemoval.htm
Old Feb 3, 2008 | 02:37 PM
DJB's Avatar
DJB
12 Second club
Removing the engine from the top is not that hard. You just have to tear the everthing off the engine first.
Old Feb 3, 2008 | 02:54 PM
Silver6sp's Avatar
ive never dropped it out the bottom, but i have pulled one out top with auto trans still on, hood on, intake was removed and motor mounts were removed. radiator and condesor out helped
Old Feb 3, 2008 | 03:35 PM
Juiced2000SS's Avatar
Out the top. Had to remove the front acc, intake, radiator/condensor/fans, but left the heads on.
Old Feb 3, 2008 | 07:36 PM
zxcasd's Avatar
Thanks for the Links !!! So far I think I'll try to go from the Bottom... Looks like the smartest way.
I'll be nice if someone make a nice "How To" Guide to do it right...
Thanks for all your help guys !!!
Old Feb 3, 2008 | 09:40 PM
1BADAIR's Avatar
depending on a few things my buddy and I can have mine out in about 2 hours or less.
I screwed up when I put my N20 on and ran the wires through the grommet by the pcm <which made it impossible to pull the engine harness out. The n20 wires are getting moved now so I don't have to leave the harness on the body again.
Auto's are easier as long as the trans lines come off the rad easy. You don't have to pull the console on them.
I'm trying to get a hoist. Then I will pull them out just to change cam/springs
Old Feb 4, 2008 | 01:14 PM
zxcasd's Avatar
Anyone Else ???
Old Feb 4, 2008 | 01:41 PM
BES Stroked Nova's Avatar
out the top was a pain in my ***. i left the heads on, then when i was hooking up to it to pull it out, my cherry picker would not reach back far enough.... go out the bottom. lol
Old Feb 4, 2008 | 02:01 PM
rpmauto's Avatar
I have done a few out the bottom, now with mine I am going to try it out the top.
Old Feb 4, 2008 | 02:04 PM
  #32
keliente's Avatar
Originally Posted by zxcasd
Anyone Else ???
https://ls1tech.com/forums/general-maintenance-repairs/857641-how-remove-engine-bottom-ls1-fbody.html
Old Feb 4, 2008 | 07:36 PM
  #33
hammertime's Avatar
Originally Posted by styoung
That's the one I was trying to find yesterday. Between that one and the one Kelly did, it should just about cover everything.
Old Feb 4, 2008 | 07:45 PM
  #34
zxcasd's Avatar
Vote Here: https://ls1tech.com/forums/generation-iii-internal-engine/858175-ls1-engine-removal-top-bottom.html
Old Feb 17, 2008 | 08:40 PM
  #35
1BADAIR's Avatar
another
