View Poll Results: Remove an LS1 engine from the Top or the Bottom ???
Remove from the Top
28.49%
Remove from the Bottom
71.51%
Voters: 186. You may not vote on this poll
LS1 Engine Removal, Top or Bottom ???
Old Feb 5, 2008 | 09:56 PM
zxcasd's Avatar
Originally Posted by 4psi
When I got my car it only had a short block in it. I figured I should just pull it from the top and I did. It was so dumb, If the heads would have been on it would have been a nightmare.
Can anybody post pictures of dropping the engine out of the bottom with out a lift??? I am not lucky enough to own a 2 post lift yet
Take a look here:
https://ls1tech.com/forums/showthrea...=1#post8639103
Old Feb 6, 2008 | 05:53 AM
Juiced2000SS's Avatar
I voted top, mine came out with heads on it and went back in the same way.
Old Feb 6, 2008 | 09:16 AM
bluehawk2's Avatar
You could avoid a lot of the scratches and scrapes in your engine bay if you pulled it from the bottom.
Old Feb 6, 2008 | 05:03 PM
crzytown69's Avatar
the guys who pull from the top where did u attach the chain to
Old Feb 6, 2008 | 05:08 PM
will69camaro's Avatar
Sex On Wheels
I attached chains to my heads where accessories go etc. I didn't scratch anything in my engine bay, it's not hard from the top and it's worked for me a couple times. It can be done fast and heads stayed on mine as well as hood staying on like it is factory. No problems at all really, besides making sure you can reach the motor over the nose or from the side.
William
Old Feb 6, 2008 | 05:19 PM
crzytown69's Avatar
i was just thinking you guys ran a chain from the front to the back like old school motor pulls i just didnt see how to connect the chain any where but the front of the motor... is this lift plate from qtp really worth it
Old Feb 6, 2008 | 05:55 PM
Z28Fistergod's Avatar
I took mine out the top, by my self, with the heads on, and the hood on. I ran the chain diagonally from the back of one head to the front of another. The only thing I didn't see anyone else mention is removing the engine mount from the K member, I think I only took off the passenger side. Doing that made enough room for me to turn the motor sideways and lift it up. It went back in just like it came out. As for being able to reach over the front with the cherry picker, I took my front bumper and core support off, and it gave me enough room.
Old Feb 6, 2008 | 08:02 PM
1BADAIR's Avatar
Originally Posted by rpmauto
. It is still way easier than taking a 4.3l out of a 4wheel drive s-10 blazer. Those suck bad.
HEHE I am getting ready to do my Jimmy
Old Feb 6, 2008 | 08:18 PM
m8w6r77's Avatar
my 1st gen s10 blazer was easy. the whole front clip was off the truck. plus it is 2wd
Old Feb 6, 2008 | 08:25 PM
4psi's Avatar
Originally Posted by zxcasd
Thanks man!
Old Feb 6, 2008 | 09:31 PM
crzytown69's Avatar
man no one has said **** about having to take the front clip off and the core support any one else do all this just to get it out
Old Feb 6, 2008 | 11:31 PM
  #32
m8w6r77's Avatar
i have a s10 blazer. it was way easier for me to take the clip off to get to everything. no leaning over the fenders.
Old Feb 7, 2008 | 06:40 AM
  #33
QTP makes a tool that bolts onto where the valley cover goes. It has a hook on it to pull the engine right from the center. I just made one of my own at work. Piece of cake. We did take the hood off though, but no scratches or anything. Can't even tell it was out.
Old Feb 7, 2008 | 08:20 AM
  #34
rpmauto's Avatar
one more con to bottom, you need a couple buddies to get it back in, coming out is easy, but going in you need many eyes and hands for the struts, ect... All the 4wd s-10 blazers i have done i found it easiest to remove the body mount bolts, pick up the body and place a short 2x4 between the body and frame. this makes access to the tranny bolts and the pesky bolts on the back of the head holding the fuel lines.
Old Feb 7, 2008 | 04:51 PM
  #35
nandofabricado's Avatar
top for the win you dont need an alignment, bleeding brakes, or risk tearing wiring harness
Old Feb 7, 2008 | 04:52 PM
  #36
works like a champ
Old Feb 7, 2008 | 05:24 PM
  #37
crashinaz's Avatar
Top. An hour to build a lift plate and a couple hours of disconnecting things and it's out. If you're working in a normal size 2 car garage, the bottom method doesn't work well IMHO. A car with out front suspension, a K member with suspension, an engine hoist, engine stand with engine and all of the other stuff makes for a crowded work environment... Of course, if you don't have a HOA and don't mind your stuff being pushed outside, then it's not a problem.
Old Feb 7, 2008 | 05:30 PM
  #38
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
Originally Posted by EastTnZ28
I had never done a 4th Gen engine swap. I bought that LS1 book and dropped it out the bottom without a lift in my basement. Pretty easy job. Just have to have some sort of cart to roll the motor, trans and K member around.
I'm more interested in your car being in your basement than anything else in this thread. I think we need pics of your house
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Feb 7, 2008 | 05:40 PM
  #39
studderin's Avatar
top....
Old Feb 8, 2008 | 12:29 PM
  #40
bigdsz's Avatar
Out the top, heads on, hood on. Only problem is my cherry picker arm isn't long enough even in the last bolt hole, just have to hang out there with no bolt. I can't imagine how high the car has to be off the ground to pull the engine with the bell housing and tranny attached, plus no way with the hood on.
