View Poll Results: Remove an LS1 engine from the Top or the Bottom ???
Remove from the Top
28.49%
Remove from the Bottom
71.51%
Voters: 186. You may not vote on this poll
LS1 Engine Removal, Top or Bottom ???
Old Feb 16, 2008 | 08:59 PM
  #61
kistlerjm9's Avatar
^^^^ label wiring what the hell is that for. bottom was easier for me due to suspension change at the same time. needed aligned after anyway so wasnt to bad.
Old Feb 17, 2008 | 01:26 PM
  #62
1BDBOTI's Avatar
i just droped mine out through the bottom of my 2002 ss, just take your grounds loose and wiring harness loose from the body and computer and throw it on top of the motor while droping it down, you can unplug the wiring from the motor when you drop the motor out.....
Old Feb 17, 2008 | 03:05 PM
  #63
pwrtrip75's Avatar
Originally Posted by crashinaz
Easy peasy...
Im sure it was fun completely disassembling the engine inside the car. Ive done this before through the bottom, so easy. You dont have to take anything off the engine or the car. Simple unbolt and drop. ( a few things need unbolting but common sense.) And coming out the top, im sure its fun crawling around under the car to try and get it lined up. How many people does that take? No way id take it through the top. ...way more work.
Old Feb 17, 2008 | 03:06 PM
  #64
pwrtrip75's Avatar
Originally Posted by Pro52R
Well......
For every 10,000 guys who removed it from the bottom...1 has done it though the top..
so I think odds are that bottom is easiest.
To go through the top IIRC you need to remove the heads,etc. So stick to the easy way
Theres also those guys who like to build model ships inside glass bottles...lol.
Old Feb 17, 2008 | 03:14 PM
  #65
SATXBlackSS's Avatar
Are ya'll leaving the headers still on? If so, how much harder is it?
Old Feb 18, 2008 | 09:31 AM
  #66
socmguy's Avatar
Restricted User
why is this thread still alive?!
Old Feb 19, 2008 | 10:13 AM
  #67
Cantalope Kid's Avatar
Originally Posted by Azrael
These motors are the ****, so they come out the bottom.
I thought these motors were the "*****" so you always start with the top first.
Old Feb 19, 2008 | 10:53 PM
  #68
LS1RedZ's Avatar
Having a lift now makes it much easier to take one out of the bottom..
Old Feb 20, 2008 | 06:14 AM
  #69
crzytown69's Avatar
i did it last night through the top. I had a buddy make a plate like qtp sells. We just used the valley cover for a pattern. The heads stayed on only think i took off was the accessories intake an valve covers . The hardest part was the two bellhousing bolts on the drivers side have to get them from underneath the car. we loosened the two bolts on the passenger side of the tranny cross member and took the two on the drivers side out.. its cake to get those two bellhouseing bolts out once you do that with a long extension or two... man that plate pulled the motor right out of there in like 10 min...now getting the exhaust off lol was like a 45 min job damn y pipe
Old Feb 20, 2008 | 09:53 AM
  #70
adillhoff's Avatar
I just cut the front right of the car off and pulled it through the right of the car.
Old Feb 20, 2008 | 12:11 PM
  #71
crzytown69's Avatar
lmao wreck the car?
Old Feb 20, 2008 | 11:06 PM
  #72
99blancoSS's Avatar
I took it out the top. Was a peice of cake. Didnt have to bleed the brakes when I was done either. Wasnt the first motor I've taken out.
Maybe if your handi-capped you have issues with going out the top. Took 5 minutes to drop it in. Lining up the mounts is a peice of cake... unless your an idiot.
to each his own, if you like dropping the suspension and re-aligning and bleeding brakes then thats your thing.... but dont dis people who dont see the value in adding extra work. I dont know of any mechanics personaly that drop it out the bottom. I know of a person or two on here who did it but none of the mechanics I've worked with would do it that way.
Old Feb 24, 2008 | 04:20 PM
  #73
Viper's Avatar
Out the top - easy with 2 guys for aligning.
Attached Thumbnails LS1 Engine Removal, Top or Bottom ???-img_0066w.jpg   LS1 Engine Removal, Top or Bottom ???-img_0064w.jpg
Old Feb 24, 2008 | 06:20 PM
  #74
stoverz28's Avatar
Viper, why did you use both sides of the chain in the front istead of diagnolly front to back? Did you need that much angle to clear? or was there just not enough room to get a chain way back there?
Old Feb 24, 2008 | 06:34 PM
  #75
Viper's Avatar
First time doing it, found it easy to maneuver for us. I imagine the QTP plate method is easier. The above pictures are motor going in; here is motor coming out. I'm guessing there are easier ways than what we chose to attach to.
Old Mar 5, 2008 | 10:14 PM
  #76
transAm-98's Avatar
I pulled it out the bottom. No messing around with headers or shitty bellhousing bolts. Did it with myself and another friend.
Old Mar 6, 2008 | 12:47 AM
  #77
Deeavi's Avatar
I agree with blanco!
My son and I have done it several times out the top. After the first time it is easy as pie. Only problem I have is bugging my friend to charge up my AC every time I put it back together. Plus space is a premium if you are in a two car garage with one side full of the wife's stuff.
Old Mar 6, 2008 | 07:20 PM
  #78
2000LS1Girl's Avatar
I pulled it out the top 6 times now.... drop ac comp to the side and tie it up same with power steering.... leave long tube headers in the car still in spot hooked up to exhaust.. take off intake and leave t56 not even dropping cross member or exhaust...i unbolt mounts from block before i lift motor.... takes me and a buddy about an hour.... like i said 6 times now.... in the last 6 months.... sux to be me.... but at least its easy
Old Mar 6, 2008 | 10:17 PM
  #79
Boosted1320's Avatar
Anyone ever take one out from inside the car?
Old Mar 7, 2008 | 01:25 AM
  #80
taws6m6's Avatar
Thats funny, me and a buddy did something similar with a 97 383 lt1 car. We put the car sitting on its rims under the frame, cut the whole clip off with a torch. We had a large forklift, and just dropped the motor onto the forks, tranny attached
