Thread sealer?
Old Feb 7, 2008 | 10:39 PM
phoenix1987's Avatar
Default Thread sealer?
What thread sealer on rocker bolts do you guys recommend for ported lsx heads? I use lock tight, but now with the ported heads, I have to keep oil from sneaking past the bolt into the intake port and don't know if the loctite is good enough. Wondering what everyone uses.
Old Feb 7, 2008 | 11:00 PM
chuckyt1's Avatar
Permatex thread sealer works...
Old Feb 7, 2008 | 11:08 PM
So should I use a thread sealer and not worry about loctite?
Old Feb 8, 2008 | 04:30 AM
vettenuts's Avatar
Blue loctite will seal as well.
Old Feb 8, 2008 | 08:41 AM
04gtod's Avatar
Blue Loctite here. I have crane rockers with studs, don't want studs to back out.
Old Feb 8, 2008 | 08:48 AM
chrs1313's Avatar
permatex number 2,non hardening will stop the leaking.
Old Feb 8, 2008 | 09:03 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Blue here
Old Feb 8, 2008 | 02:41 PM
Viper's Avatar
Permatex here, with blue under the washer itself (not on the threads).
Old Feb 12, 2008 | 12:11 PM
Are you talking under the bolt head?
Old Feb 12, 2008 | 12:25 PM
Viper's Avatar
Yes, just a dab under the bolt head.
Old Feb 12, 2008 | 01:24 PM
I think I will use the blu loctite on the threads and a dab under the head bolt. Thanks guys.
Old Feb 12, 2008 | 03:45 PM
Viper's Avatar
To clarify, I use the permatex on the threads themselves and the blue loctite under the bolt head.
Old Feb 12, 2008 | 08:01 PM
Got ya
