Motor falls flat after 6800
TSP said the cam is out of it's RPM range by 6800. They said they setup the spring height to 1.81-1.82 when assembled. They suggested I could try reducing the installed height to 1.79 and that should take care of any valve float. They didn't feel it was necessary to shim to within .050 of coil bind for this cam. If adjusting the installed height didn't fix the issue, they said to look in the tune.
Raymac said I'm experiencing valve float. They also said the cam is out of RPM and when it gets that far out of it's range it will cause float. They thought I might be able to get another 100RPM by switching from 3/8" pushrods back to 5/16" pushrods (as well as some HP), but the best bet is to get a better valvespring than my current Platinum Duals sold by TSP. The have a drop-in kit which would get me another ~30-40lbs open pressure. They also said that Ferrea recently released a valve spring kit good to .670 lift, but Ferrea wants about $1000 for the kit. Um, no...
Raymac also mentioned that they always shim to within .050 of coil bind on street motors, and within .030 of bind on race motors.
So I guess I'll try swapping back to 5/16" pushrods just to see if there's any more power. If not, I'll keep the 3/8". I'm not sure if getting that extra 400RPM is worth the hassle of buying new valvesprings and installing them. But I guess for peace of mind I'll need to confirm the current installed heights.
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
So are there any how-to's around here for resetting the installed height? I've got a comp cams 4928 spring micrometer that I bought but never ended up using from years ago, but I don't have any experience installing valvesprings or altering the setup. To reduce the installed height, I take it I'll need some sort of shim... Summit lists a variety of ID and OD shims, what size do I need? Heck, I don't know how to determine coil bind either. Can I measure that or do I rely on published specs?
I had a custom ground cam. TSP set thier stuff up for their cams is my guess and no one takes that into account.. at least we didnt
After a brief search, it looks like my friend has done this before from another post. How much of a pain is this with the heads installed? Can I just leave my RPM limiter say at 6600 for now pending setting the correct installed height or having better springs installed altogether?
Int Dur / 2 + ICL - 180 = IVC
228/2 + 112 -180 = 46*
- Will my Caddy lifters have any problems handling the additional spring pressure?
- Does additional spring rate have an effect on spring life, guide life, or any other valvetrain component?
Jim, shim your springs to within .050" of coil bind, then retest. I'm pretty confident you can rev to 7200 with ease. I have a 224/230 cam in my TA and even with heavy 2.08 intake valves and 3/8" pushrods, it revs to the 7200 rpm rev limiter with ease. That's using the same springs you are, but with a 1.775" installed height. You'd be amazed as to what .040" of shimming will do for valve control.
You know this might explain a lot of the differences people see with the almost same combination... Spring pressure is not looked at enough. I didnt even think about it with the Term heads issue. Maybe that was the whole problem.
Is it the lobe and pressures that need to be matched?
https://ls1tech.com/forums/showpost....8&postcount=17
Also, it looks as if my .050 IVC is actually 38.6 per the cam doctor report, so it's worse than 41.5
https://ls1tech.com/forums/showpost....59&postcount=6
