Motor falls flat after 6800
My wideband sensor appears to have seen better days so I bought a new sensor and installed it this morning. It appears to be 10-15% rich at WOT all the way through the RPM band.
Motor is a 347 with stock crank, Wiseco pistons, Eagle H-beams, Clevite bearings, ARP rod bolts, 227/235 110+2 .645/.650 cam, LS1 rev-kit, TSP 5.3L heads, Platinum dual springs, 3/8" pushrods, stock rockers and LS6 intake. That's the basics for the longblock but I can give further specifics if needed.
The current motor was built last summer as a result of spinning a lifter. The old motor would pull to 7200 without a problem. This motor is using the crank and connecting rods from the previous motor
Any ideas on what would cause the flatlining RPM?
valve float? can you post the graph, that might help someone. I cant think of anything else. New heads so there cant be build up, how did the intake look. I imagine if it had oil leaking out or a build up around the ports of it you would have noticed.
The intake was oily when we swapped it from the old motor, but I cleaned it out before re-installing it. I don't have a legitimate catch can, just a clear fuel filter inline. It does burn oil. We used lock-tite on all the rocker arm intake threads as sealant.
Fuel system is stock except for flow-matched 42lb Lucas injectors. Fuel pump or fuel pressure maybe?
The first dyno's on the motor, a few months back, are in this thread: https://ls1tech.com/forums/dynamometer-results-comparisons/815233-first-dyno-prc-5-3-s-patrick-g-cam.html.
The last dyno's (just pictures of the sheets, post #8) are in this thread after new headers: https://ls1tech.com/forums/generation-iii-external-engine/843960-norris-motorsports-installed-my-arh-headers-today.html
Regarding the cam and RPM, it appears to peak around 6300 and carries nicely to at least 6700. It doesn't look peaky at all, and shifting at 7200 was dictated in the cam request so I could take advantage of mechanical gearing and not shift as much. Again, this new motor received a new cam, new heads, new pushrods, new injectors, new oil pump, new pistons, new Caddy lifters (forgot to list those earlier) and the rev-kit instead of the lifter trays. A lot different than the old motor. I tried to build this motor to easily handle 7300RPM's and I'm irritated it can't get there.
As long as you've exhausted all potential valve control issues (springs shimmed to within .050" of coil bind, proper wipe pattern on valve tips, precise plunger depth on hydraulic lifters), you could retard your cam 2-3 degrees and this would help your top-end. But expect to take a hit in the low and mid-range as a result of decreased dynamic compression. Again, it's a compromise.
Check all the valvetrain issues mentioned above first.
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Something else I noticed is that my MAP gradually climbed instead of immediately hitting 100kPa. It behaved this way earlier in the log at frame 27140 but there it reached 100kPa before 4000RPM. I removed most of the PID's not necessary for VE tuning so it's hard to determine what I was doing with the throttle, etc. When I'm VE tuning and I mash the throttle it goes immediately to 100kPa so I'm confused why it didn't do it when I wasn't watching the laptop
