what can i take my car to rpm wise?
just wandering what i can run my car up to ive been looking at some dyno vids of others with the ms4 cam that i have and bolt ons. im running to 6400rpm right now can i go higher? im on stock bottom end stock heads stock ls1 intake...just curious thanks justin
i definitely would not go to 7000 on a stock bottom end. my cam makes power past 6500 but i have my rev limiter set there to save my rods. these engines are good top end runners so if u want to take it that high i'd recommend replacing some bottom end parts unless u want to throw a rod out the block
I would try to shift at 6500 to 6700 RPM because of the stock bottom end (rod bolts and stock bearings) and its a hydraulic cam, if you were solid lift and had a real nice set of heads with ajustable roller rockers then you could more than likely gain something up in the higher RPM. I personally try to shift my car at 6500rpm because by the time I see 6500 on the tack and get it shifted its a little higher.
with only rod bolts, on stock bottem i hit 7100 rev limiter from time to time, but try and shift it at 6800 on motor and 6300 on bottle with no worries, im not too scared of it. but thats just me.
