LS7 componets in a LS1?
Few quick questions on parts interchanging between a LS1, and the LS7
1. Can I use a LS7 Crank and Rods in a LS1?
2. Will LS7 valves fit in LS1 Heads with machining?
Thanks
2. no
l92 is the closest u will get to a ls7, and even then none of the parts will interchange,
ls7 is "top gun" lsx motor and most all parts are specific to it.
1. rods yes, however will have to deck your block or get a set of custom pistons. Pin fit the rods for .927 pins
Crankshaft i'm gonna say no, unless you put all C6 Accessories and LS7 oil pump/pan on the motor
2. No
Kurt
Using an LS7 crank is a pretty well covered topic if you keep searching. Once the snout is machined, you can using a wet sump pump and gear drive with a standard pulley (Fbody, truck, etc). The machining of the snout is so that when shorter single stage wet sump pump is used, here won't be a big gap between the balancer huh and the pump gear drive.
