track time question
Old Mar 13, 2008 | 12:23 PM
iGOTaLS1's Avatar
Default track time question
I have an A4 99trans am with qtp long tube headers, ls6 intake and a whisper lid. the best i have run is a 13.7. is this a normal time? and if its not could you please give me suggestions on how to improve.
Old Mar 13, 2008 | 12:48 PM
93redBIRDman's Avatar
what was your 60' time and then we can tell you if your time is normal for the mods. And also, what mph? If your 60' is crappy and you have a decent mph, then you just need traction...
Old Mar 13, 2008 | 12:51 PM
tee-boy's Avatar
launch the car. Dont spin the tires and don't let the motor bog.
Old Mar 13, 2008 | 12:52 PM
tee-boy's Avatar
If your mph is not ok... I'm guessing 108, then give it a new set of plugs, wires, and fuel filter.
Old Mar 13, 2008 | 12:57 PM
SD99TA214's Avatar
need more info... if runnin stock gears and stock street radials, this is about right.
Old Mar 13, 2008 | 01:00 PM
CaseyEaterMach1's Avatar
More important than what everyone else asked is what is your track's altitude because 13.7 could be a great run if you’re high up. If you’re around sea level though then that's not so hot. Rule of thumb for 60' times is that for every 1/10th you pickup you'll gain twice that at the end of the 1/4.
Old Mar 13, 2008 | 01:04 PM
silver-mod-o's Avatar
Custm2500's #1 Fan
13.7@108??? turbo car??? LOL a high 13 should be right around 99 to maybe 101... depending on elev, and traction.
Old Mar 13, 2008 | 01:05 PM
I've read everywhere that for every 1/10 in the 60' it equals out to 1.5x in the 1/4, but who knows, it's just a estimation anyways lol
Old Mar 13, 2008 | 01:11 PM
chevrolet02z28's Avatar
uhh dunno where u r but i ran mine stock on 90 degree day and it ran a 13.7 at 104.... 99-101 is to low
Old Mar 13, 2008 | 01:17 PM
021less's Avatar
exactly, this is probably the most important info needed. My car runs 1/2 second slower at atlanta dragway (elevation is around 1300) than it does at silverdollar (400' elevation). 60' is probably the second most important factor.
Old Mar 13, 2008 | 01:28 PM
Custm2500's #1 Fan
no, its efficient... thats making the most of every one of those 1320 ft... I went high 13's this weekend at 100-101 all day due to traction... it was cutting 2.4 60ft's this is also in a 5.3L ext cab truck..., so if a less-modded car, with a decent 60 is running high 13's then he should trap a little slower...
Old Mar 20, 2008 | 01:15 PM
iGOTaLS1's Avatar
I dont have any of my old slips so i cant remember my 60' time but I do remember that I was trapping around 103-104. I am also running stock gears.
Old Mar 20, 2008 | 01:18 PM
PewterScreaminMach's Avatar
Where are you racing? That's a big factor. At most tracks, 103-104 is a slower bone stock time, and 13.7 would be kind of slow for a bone stock A4. The track elevation and weather is going to factor in big time depending on where you are racing.
Old Mar 20, 2008 | 01:19 PM
And just so you know, this thread will probably get moved to the Drag Racing Results section. You're in the internal Gen III tech section.
Old Mar 20, 2008 | 04:41 PM
bad6as's Avatar
fyi when my car was all stock its a 1998 z28 m6
my best was 13.7 @ 101 with a 2.0 60ft
lid and cat back was 13.5 @ 105 with a 2.2 60ft
added longtubes 13.4 @ 109 2.2 60ft
added a tune slicks and ls6 intake and 12.4 at 112 1.77 60ft
added cam and on street tires 12.5 116 2.0 60ft
Old Mar 20, 2008 | 05:49 PM
Bizzles's Avatar
Idk... I went 13.155 @ 106.24...at atco in NJ
ran it with a whisper lid, 160 thermostat, and an open stock Y, on shitty *** tires.
I have a fully optioned z28 w/ t-tops, factory 3.23s, cut a 2.0 60'.
Old Mar 20, 2008 | 05:53 PM
COD02SS's Avatar
That time does suck but maybe if you had 2.73's.
Stock time in sig
Old Mar 20, 2008 | 06:08 PM
LS699TA's Avatar
NORMAL...
i bet he left on green at the pro tree... -.5 sec
Old Mar 26, 2008 | 02:31 PM
iGOTaLS1's Avatar
Im racing at Atco in NJ
Old Mar 29, 2008 | 08:38 PM
iGOTaLS1's Avatar
alright new time last night at atco
13.4 at 106mph
