i need ls1 engine at least 550HP
We can set you up with a mild manner'd 402+ inch motor.
for built 4l60e's check out FLT's transmissions that we sell.
http://www.ls1speed.com/catagory.cfm...y=Transmission
the link is empty and i opened other link
http://www.ls1speed.com/enginepackages.cfm
but no ls1 engine and no horse power written.
i found some sites can u help me which one is good for ls1 or ls2 or lsx engines and th400 trans coz i want to buy it for my car
patmusiperformance
sonnysracingengings
gofastzone
mastmotorsports
speedomotive
nelsonracing
mti motorsport
worlcastings
scott shafiroff
lg motorsport
coan trans
rosslertrans
patmusiperformance
sonnysracingengings
gofastzone
mastmotorsports
speedomotive
nelsonracing
mti motorsport
worlcastings
scott shafiroff
lg motorsport
coan trans
rosslertrans
No one yet has asked why 550rwhp. Did you make a bet with someone that your car will put that down on a dyno or something? Why not 551rwhp?
What will this amount of power do for you and what will you be using it for?
victory racing engines: take your pick of the big cube motors. most should put down 550rwhp if you put a big enough cam in them.
if you look to the right..... there are plenty of sponsors that can get you whatever you need. Just click and buy or call. Everyone has answered your question, you asked for an ls1 which is a 346ci motor. If you want an LSX motor, well that is a different story, many many options to chose from that can go way past your goal if you have enough green.
if u read the title u will see that i said at least 550HP means more than 550 because i know somebody his car made 540RWHP with lq9 block and 408 stroker but i want alum. block no matter if its ls1 or ls2 or lsx or any stroker size but i need it fit my car and my coputer with harness
you are the firest one helped me
Depending on what you want to do and how you want to do it.. forged internals FI or nitrous or a bigger cubed block with better heads cam intake and great exhaust bigger injectors.... it just depends
