Patrick G or PREDATOR-Z = DCR help!!!
Old Mar 15, 2008 | 10:38 PM
cdoggy81's Avatar
Default Patrick G or PREDATOR-Z = DCR help!!!
You all are the go to guys for this...
I'm having a heck of a time calculating my DCR. I found & used the excel spread sheet based on Comp grind cams.
Here is what I have for my setup:
Heads are 241's milled down to ~58cc (~11.5 CR)
Stock GM MLS gaskets
Cam is F13 (230/232 .595/.585 114*)
Punched in the #'s I knew into the spread sheet & got an error on the DCR tab (orange) but got it to work on the DCR Manual Calc (Blue Tab). I calculated out the following:
Static Compression Ratio 11.58
Dynamic Compression Ratio 9.00
Static looks right but got a DCR of 9.?.?.? That has to be not good b/c I thought mid to upper 8's we about the max for 93 octane pump gas.
If I did it correctly & my DCR is 9 I am worried it will be too high.
If so how do I fix it? Thicker gasket? Could I remove some of the material in red to increase the CC size? Would that mess up the swirl & flow of the heads? HELP
Old Mar 16, 2008 | 02:12 AM
PREDATOR-Z's Avatar
I would need the .006 advertised durations of that cam.
If you are indeed over 9.0 DCR, you can retard the cam a bit like 2* or 4* to lower DCR.
Also you can un TR6 plugs (colder than stock) to help with detonnation and through tuning (reduced timing)
Old Mar 16, 2008 | 03:16 AM
cdoggy81's Avatar
I think they are 279/281 (XER lobes)....
Good idea to use the TR6 plug.
Old Mar 16, 2008 | 07:29 AM
oange ss's Avatar
I got
SCR = 11.56
DCR = 8.67
assuming the cam is advanced 2* for 112 ICL
Old Mar 16, 2008 | 08:27 AM
DrkPhx's Avatar
That is a Futral cam. They use Cam Motion to grind their cams. XER is Comp Cams.
F13
.050" 230\232
.200" 151\150
.006" 280\284
Assuming -.007 deck height, .0053 compressed head gasket and 114+4 (a guess) I came up with 11.58 and 8.81.
Old Mar 16, 2008 | 08:33 AM
oange ss's Avatar
in that case...
114 LSA / 112 ICL
SCR = 11.56
DCR = 8.63
114 LSA / 110 ICL
SCR = 11.56
DCR = 8.79
Old Mar 16, 2008 | 06:55 PM
Gh0st's Avatar
Jedi Master
What are the numbers for the following setup:
226/228 581/585 114 + 4
Stock height head gasket
60.9cc LS6 Heads
Old Mar 16, 2008 | 07:01 PM
oange ss's Avatar
need adverised duration (.006)...who's cam ?
Old Mar 16, 2008 | 07:26 PM
studderin's Avatar
do you have any chamber work done?
Old Mar 17, 2008 | 07:56 AM
cdoggy81's Avatar
DrkPhx, THANKS for the #'s!!!
OK, so it is looking like 8.6 to 8.8 DCR. Is this too high?
No chamber work done, just milling the heads. If I need to do something what can be done? Can I open them up in the red area in the pic? Will that effect the flow?
Thanks for all the help guys
Old Mar 17, 2008 | 10:08 AM
PREDATOR-Z's Avatar
Nope, not a good idea IMO, that is the quench pad area and you'll create turbulence into the valves.
Are the heads allready milled?
Old Mar 17, 2008 | 10:03 PM
cdoggy81's Avatar
Yes, they have been milled already.
So no cnc work to the quench pad area b/c of created turbulence?
Old Mar 19, 2008 | 10:06 PM
cdoggy81's Avatar
Any ideas?
Old Mar 19, 2008 | 10:31 PM
oange ss's Avatar
was using -.008 for deck height, if yours is lower that will help some, if not using a .060 gasket will bring the numbers down to 8.5 DCR, 11.3 SCR
Old Mar 20, 2008 | 12:41 PM
cdoggy81's Avatar
Is the stock LS1 deck height .-006" or -.008"?
The cheaper GM gaskets are how thick, .052"?
Where can I get some cheap .06" gaskets?
Thanks
Old Mar 20, 2008 | 02:51 PM
david vericker's Avatar
I guess it's hard for me to understand why you mod a car and then de-tune it and loss the optimal performance level of the set up. The 93 octane fuel will not become a serious issue until the engine is put under max load (WOT). If you mix 103 and 93 at a 50/50 ratio = 98 octane which will be more than enough to protect the engine from detonation when running it hard. Yes, that is somewhat more expensive, but de-tuning is like taking two steps forward then taking one step back. Just my 2 cents.
Old Mar 20, 2008 | 02:52 PM
oange ss's Avatar
had an 01 motor that was -.008
the 98 motor i have now is right at the same, that's why I was using that deck height, i believe the older the graphite gaskets were .053, the new GM MLS i read are suppose to be .060, but cant confirm that measurement
Old Mar 20, 2008 | 02:53 PM
oange ss's Avatar
i used the .053 gasket for the initial DCR calc..
Old Mar 21, 2008 | 12:10 AM
cdoggy81's Avatar
I'm not de-modding. I'm building an engine with parts I have.
Thanks for the help oange SS
It looks like I need to call Futral & TSP...
