Better CAI setup
Old Mar 24, 2008 | 12:20 PM
animuL's Avatar
Default Better CAI setup
I was noticing that the factory air intake setup seems pretty restrictive. I have an SS with the SLP lid and it does appear that it pulls some air thru the hood scoop, but the rest of the air is coming off the a/c condensor and radiator. It looks like the bottom of the airbox was already opened up by a previous owner. So I am wondering if there is something else that can be done. I kinda wonder about drilling a couple 2-2.5" diameter holes all the way thru the frame under the air box, and then welding some pipe in those holes to keep it rigid.
Old Mar 24, 2008 | 12:24 PM
silverbandit0996's Avatar
you'd probably get more help in the external section.
Old Mar 24, 2008 | 12:28 PM
animuL's Avatar
Oh DANG can we get this thread moved for the newb?
Old Mar 24, 2008 | 12:30 PM
BLACK2001SS's Avatar
if its open then the A ram air kit would be nice as lond as the hole in the bottom of the air box isnt too big. And some say that blocking off stock holes for air causes a vacume effect which is better for preformance.
I have an ss and deleted the hood and use a SSRA kit with a lid. worked great at the track.
Old Mar 24, 2008 | 12:39 PM
teke184's Avatar
i say go for the SSRA setup instead of hacking up the frame.
much more functional of a ram air than the SS hood...MUCH
Old Mar 24, 2008 | 04:39 PM
chrs1313's Avatar
check out SUX2BU's intake i think you might like it...or try a search for custom ram air under my name if you want about 20rwhp gains
