cometic Head gaskets reusable? Not according to cometic
Old Apr 8, 2008 | 07:41 PM
TT_Vert's Avatar
Default cometic Head gaskets reusable? Not according to cometic
basically the only reason I purchased them was because they were reusable And at that price I had expected them to be. But when I took the head off the other day, i noticed the rubber coating had come off some and they were pretty useless so I sent them an email. This is what I got back.
Our gaskets are only recommended to be used once.
Kevyn Kistner
Technical Sales
Cometic Gasket
Needless to say I am pretty disappointed in this..
Dave
Old Apr 8, 2008 | 08:09 PM
TLewis4095's Avatar
Cometics are 1 use. We use them on FI builds & high compression NA builds, but on most stock cube builds the GM gaskets work great.
Old Apr 8, 2008 | 08:10 PM
thebart455's Avatar
ive never used a head gasket twice
Old Apr 8, 2008 | 09:09 PM
TT_Vert's Avatar
problem is, I need a .040" gasket
Dave
Old Apr 8, 2008 | 09:12 PM
waterbug1999's Avatar
Thats sucks... I have the same .040 gasket as you and I have to pull off my heads.
I was under teh impression as well that you can reuse them.
Who else makes a .040 gasket that is not expensive as hell.
Old Apr 8, 2008 | 10:55 PM
Dmoney's Avatar
Alot of people have reused them. I've been runnning a "used" set of .040 for almost 2 years now. They were pretty beat up when I received them, but I cleaned them up with carb cleaner, then used copper spray and haven't had a problem......................
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Moving to Internal
Old Apr 9, 2008 | 07:43 AM
brad8266's Avatar
Some people reuse them with success. I wouldnt try to reuse them though.
Old Apr 9, 2008 | 08:27 AM
Phil99vette's Avatar
7 Second Club
I've reused a set 6-7 times. Cleaned them with acetone and sprayed them with copper spray. Car went mid 10s on motor and low 10s on nitrous having issues.
Old Apr 9, 2008 | 09:09 AM
landonew's Avatar
there just head gaskets. Buy another set! They aren't that expensive, and it would suck to have to buy another set of heads.
Old Apr 9, 2008 | 09:10 AM
brad8266's Avatar
Reusing them would not result in having to replace heads. The gaskets would just leak.
Old Apr 9, 2008 | 09:25 AM
bjamick's Avatar
Now tell them what that can lead to .
Old Apr 9, 2008 | 09:41 AM
brad8266's Avatar
Coolant in your oil is the most common.
Old Apr 9, 2008 | 10:07 AM
xBROKEx's Avatar
they dont recomend it but that doesnt mean you cant, just sounds like them trying to get people to buy new ones all the time.
Old Apr 9, 2008 | 02:27 PM
Obviously you have not bought a set.
Old Apr 9, 2008 | 03:32 PM
Bill Bowling's Avatar
I think the last set cost me close to $180.
Bill
Old Apr 9, 2008 | 05:09 PM
Originally Posted by Bill Bowling
I think the last set cost me close to $200.
Bill
No doubt.... I forgot what mine cost, but I think it was ~160.
This guy thinks they are cheap. Not cheap in my book.
Old Apr 9, 2008 | 05:12 PM
HEMIETR's Avatar
I've seen them from $75-$90 ea.
Old Apr 10, 2008 | 02:02 PM
TT_Vert's Avatar
Yes, they are not cheap. I need a .040" gasket. I did reuse them once but this time when I pulled the head, some of the rubberized coating on the gasket came off.
Dave
Old Apr 18, 2008 | 02:40 PM
TT_Vert's Avatar
so is anyone else using an alternative .040" head gasket>
Thanks
Dave
