compstar rods and diamond pistons
Old Apr 9, 2008 | 12:15 AM
daniel6718's Avatar
Default compstar rods and diamond pistons
how do these compare to other options..thinking about a stock cubic inch turbo build and going for about 900 rwhp
goana coat the pistons...think this stuff will hold together with enough fuel and good tune
it wont be raced daily and will be on low boost but im building it to outlive my goals
Old Apr 9, 2008 | 06:24 AM
allngn_c5's Avatar
Looks like your are in the sam boat as me, but I am staying N/A. I too gotta figure out what to go with. I am leaning towards the same brands as you though. Good companies from what I have been reading.
Old Apr 9, 2008 | 09:28 AM
white99's Avatar
Callies rods and Diamond pistons are usually within a gram when it comes time to balance the rotating assembly. I personally went with Compstar rods and Diamond pistons. You should be fine with a dish piston for lower compression. I'd upgrade the crank.
Old Apr 9, 2008 | 09:50 PM
daniel6718's Avatar
ttttttttt
Old Apr 10, 2008 | 05:46 PM
daniel6718's Avatar
jkljhkl
Old Apr 10, 2008 | 06:11 PM
allngn_c5's Avatar
Shortblock with cam, lifters, everything minus heads, or longblock minus heads. Sounds like it might be a good pickup.
Old Apr 11, 2008 | 12:45 PM
daniel6718's Avatar
gfyjgfhj
Old Apr 12, 2008 | 12:05 AM
daniel6718's Avatar
tttttttt
Old Apr 15, 2008 | 11:28 PM
daniel6718's Avatar
tttttttt
