Stock Ls1 Pushrod Length???
Old Apr 9, 2008 | 10:51 AM
jattgunman's Avatar
Default Stock Ls1 Pushrod Length???
Can anyone tell me the stock pushrod length and size??every parts store I called is giving me a different length...anywhere from a 7.138 to a 8.103 or sumtin...I thought the length has to be exactly 7.4??? and I dont know what diameter..
(LS1 Stock Pushrods)
Old Apr 9, 2008 | 11:22 AM
JPH's Avatar
JPH
7.400 Length, 5/16 Diameter
Old Apr 9, 2008 | 11:29 AM
Frans96SS's Avatar
what he said....
Old Apr 9, 2008 | 02:37 PM
Shawn MacAnanny's Avatar
Isnt the stock length more like 7.385 and not 7.400 or something like that? Less lifter preload from what i understand.
Old Apr 9, 2008 | 02:45 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Yes, stock is shorter than 7.400". Most use a 7.400" when going to an aftermarket camshaft because of the smaller base circle...smaller base circles need a little extra length on the pushrods.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Apr 9, 2008 | 04:38 PM
Yeah i had to run 7.450s for my cam because of the smaller base circle. Didnt the Ls6 cam have a larger base circle too with like 7.350 pushrods? Off topic i know just trying to learn haha.
Old Apr 9, 2008 | 08:38 PM
GuitsBoy's Avatar
Stock is 7.380 gauge length what all the documentation ive read. I dont have a way to measure gauge length, but they mic out to 7.396 total length. Figure most pushrods go by gauge length, so theyre about .020 shorter than standard 7.400 aftermarket pushrods.
Old Apr 10, 2008 | 07:10 AM
vettenuts's Avatar
Rough coversion with 0.100" diameter hole is
Gauge Length = Overall Length - 0.017"
so your numbers come out OK. I have measured then at 7.385" gauge length.
Old Aug 26, 2008 | 05:37 PM
Mike96z's Avatar
can we get actual proof from GM of the size...
7.380 or 7.400
Old Aug 26, 2008 | 06:10 PM
vettenuts's Avatar
I have measured a few times and come up with 7.385". Not sure 0.015" is that big a difference unless you are using lifters that have a tight tolerance on preload like Comp R.
Old Aug 26, 2008 | 09:09 PM
dz999's Avatar
It's a good idea to get a pushrod checker to determine what pushrod you need. It seems like every setup is a little different.
Old Feb 13, 2014 | 02:52 AM
lr4 colorado v8's Avatar
So what length pushrods do I need? Lr4 4.8L V8 swapped in a 2006 GTO LS2 cam
stock base circle 1.552" measured (Gm spec 1.552")
Ls2 cam circle 1.525" measured (Gm spec 1.520")
Stock rods 7.380" (I guess even though they call them 7.4") ???
1.552-1.525 = 0.027
1.552-1.520 = 0.032
7.380+0.027= 7.407
7.380+0.032= 7.412
so I need rods between 7.407 and 7.412 ?? WTF were do I find those and is my math right? I'm thinking either 7.4" or 7.425" someone said 7.45"but won't that bottom out my lifters?
Were can I find true 7.4", and not this pseudo "7.380" that everyone calls 7.4"so confusing!
Also what is gauge measure for length? never heard of that before?
Old Feb 13, 2014 | 03:14 AM
Jut read you need to divide by 2? Is that because of the diameter verses radi?
so then it would be
0.027/2 = 0.0135 + 7.380= 7.3935
0.032/2= 0.016 + 7.380 = 7.396
Looks like 7.4" push rods are in order??
But why does rock auto list new stock push rods as 7.3180" must be a miss print? They say it on every LS based motor I can find?
Old Feb 14, 2014 | 05:08 PM
JPH's Avatar
JPH
1.552-1.525 = 0.027
1.552-1.520 = 0.032
7.380+0.027= 7.407
7.380+0.032= 7.412
Are you an engineer?
