Still Ticking!After Pushrods
After a night of racing and "overrevving" the car a lil bit I noticed a ticking sound coming from the engine or under the engine...Well I changed out the pushrods and the ticking did get slightly better but its not fully gone ..its less noticeable but still the there helppppp
Ive already retorqued them...Hmmm so a bad lifter maybe?by lifter your reffering to the rockers right?
they seemed to be ok from what it looked like...the sounds coming mostly from the the drivers side/Under the car..what should I check for in the lifters?
I down shifted and overreved the car also and it happened from there. Car ran ruff and was hearing the ticking noise coming out of my exhaust tips! Snap a pushrod and bent like 4 others. Replaced with stockers (got them for free) and cars drive fine, so i figured bad lifter. So i guess its time to save up for heads/cam now since i have to tear it down.
Oh and if you ever take your heads off to replace your lifters, have your heads checked and make sure the valves arent bent as well
the LIFTERS are under your heads. You must pull the heads to get to them. Most likely a plunger on the lifter failed and it needs to be replaced. Hopefully you don't have any rod damage. I ended up having 3 bent pushrods, failed lifter, spun rod bearing, rod knock, etc...
ahh damm lolz this sucks...So far shes driving pretty dam good but it looks like I have alot work and money to put in her now...So im guessing checking the lifters isnt something that ill be able to do...Or is not that hard?I just read a how to on removing heads and it doesnt look fun....
maybe let her break and then just build her better??
then the noise got worse and worse where we decided to pull the engine apart...
the heads aren't an easy job. You definatly need help if your a beginner at this stuff. But many people on here have done it by themselves...
www.ls1howto.com
yea I read the ls1howto write up lolz im pretty sure I could do it with my dads help and everyone on the forum ive got the tools...But ill wait a lil bit and see how the car runs..cus my dad will prob flip out
so after showing a couple of people that I know the sound ,theiire all saying that its prob not a big deal and one dude said it might be a exhaust leak since its coming from the bottom of the engine..and my dad told me not to tear it apart even though I told it would be alot cheaper to figure it out now than later...he said hell pay if it goes bad cus he thinks it wont...o well Im pretty much stuck
my money is on the start of an exhuast leak that you just cant see yet, but i would do a compression check, and leak down test to rule out anything serious, if it all checks out ok, do like dad said and just drive it..... get louder exhaust or a bigger amp and speakers, that will cure it.lol
Lolz Im still not sold on the exhaust leak because its more of a metal sound but then again im always proven wrong haha...Hopefully its a exhaust leak but that wouldnt explain the sound getting quiter after I changed the pushrods.....maybe I should throw my sub back in there lolz problem solved until the car breaks down
im pretty sure I could tear the car down in one good day and check the lifters..would I have to replace my head bolts and gaskets to ?
well its hard to describe it and know from talking about it..... but if it sounds like a lifter and is lower and more on one side that is my bet.... but more metalic and down low scares me more than it being a lifter.... um yeah put your sub back in and pray.lol
