383 Cam?
Old Apr 12, 2008 | 08:50 PM
2000 cam'n SS's Avatar
Default 383 Cam?
Im in the market for a new cam and im not sure as to what to get...So my set up is a 383 with heads cam and soon to be fast 90/90 combo...The cam i have now is peaking at about 6000 to 6200 RPMS and is netting me about 419 to the wheels....Its an older cam and i just really would like to try something a little up to date and that will spin a little more and still make power up top....Drivability is not much of an issues since i dont drive this car except for the weekends and to the track to race it....Also i am spraying nitrous on the car to and need something that will work good with that too....Any help will be appreciated
Old Apr 12, 2008 | 10:00 PM
HottLS1Z's Avatar
whats the cam thats in there now? Give some detail on your setup, what heads, what CR? M6 or A4? Gearing?
Old Apr 12, 2008 | 10:12 PM
The cam is a lunati ground cam that MTI offered probably back in 2002 or so....Heads are stage IIE heads from MTI and the Compression level is about 10.9 to 1 and it is a six speed car that will more then likely be changed soon to an automatic...Gears are 4.10s.....Im not really sure what the specs are on the cam but i think that its around 232 237 598 595 on 114 LSA
Old Apr 12, 2008 | 10:22 PM
Z28Fistergod's Avatar
I bet that 90/90 will help out alot. If I were you I would do the 90/90 first and see what that does for your current combo. If that's your plan let me know how it works out for you.
Old Apr 13, 2008 | 11:07 AM
HottLS1Z's Avatar
I'd say go for something in the 240's durations and around 600-620 lift would work out nice.
Old Apr 13, 2008 | 11:45 AM
TXZ28LS1's Avatar
for a 383 how bout an MTI Z1 236/236 or a VENGEANCE VRX5? those sound like good cams.
Old Apr 13, 2008 | 01:04 PM
JPH's Avatar
JPH
I would use something in the 236/242 range myself.
Old Apr 13, 2008 | 11:50 PM
BOTTLEFED383's Avatar
i just got mine built waiting to get pcm back from tuning but i went with TSP texas giant 248/254, .611"/.613" 114
Old Apr 14, 2008 | 12:10 AM
02 BLK WS6's Avatar
You can try something like this or call a few sponsors and see what they recommend which is what I'd do. If this is a weekend/strip car, I'd go big. If you DD or drive a lot, go moderate. Your TUNE is the key to getting the maximum out of your set up.
Old Apr 14, 2008 | 05:42 AM
I wanna go big cause i have been thinking really hard about building a 408 too...But if i could get about 475 to the wheels on motor with my current set up then ill probably just stay with the 383...I want to spin it to a max of probably 6800....Would a Texas Giant Be to much cam for that
Old Apr 14, 2008 | 07:34 AM
Sigforty's Avatar
I am making 487 rwhp with a Futral 239 243 cam.
Old Apr 14, 2008 | 09:45 AM
crzytown69's Avatar
thats what i went with you will love it untill you get stuck in red light green light land aka as stop and go traffic... it dosent like driving 800 to 1200 rpm
Old Apr 17, 2008 | 08:05 PM
so far im liking it pulls good cant wait till is spray a 200 shot through it just dont like the race that goes on in my instrument cluster between my speedometer and fuel guage and its my daily driver
Old Apr 17, 2008 | 10:30 PM
XtraCajunSS's Avatar
I am putting together an ET 245 headed 384 as I write this. Its got a FAST 92/92 combo and the cam is a 247/254 .657"/.622 110. I'll post power/torque numbers and track times when we get it finished...
Shane
