Best heads for 224 cam with 112 lsa?
The PRC 5.3 is a good head and good deal, will go with that cam nicely. MTI just released new pricing on their ported heads and those would be another great option, TEA has 5.3's as well as ET.
If you wanted to spend more money and step into an after market head then you have AFR, ET, TFS, DART, Edelbrock.. all fine choices. With your cam no need to shave the heads, you should retain plenty of low end grunt with a 224 cam. LS6 intake is fine, or you can step up to a 90/90 or 92/92 as it is now.
I would go with the stqage 2.5 5.3s from TSP, they flow great and for about the money cant be beat. My cam is a 226/232 and I think I am going to try TSPs new 2.5R head which has a 2.055 intake valve for a little more flow. You wont find these on their site yet as Jason just finished them but you can contact him if you are interested.
I have a 224/224 .581/.581 112 comp cam
on polished ( cleaned up a few burs but not ported) 243 LS6 heads on an 03 LS6 block. Comp 981 springs
TPIS LTs, Random Tech High flow cats and X-pipe then straight pipes.
underdrvie pulley, my own CAI, TPIS tb, 3qt accu-sump and oil cooler, MN6
Just over 400 rwhp and 400 rwtq
LS1Tech Premium Sponsor
The shorter intake runner on the 5.3L, as well as the smaller combustion chamber make the 5.3L the more popular choice for street use!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Moderator
The 0.024 mill with the cometic will give better quench & produce a little more power. I did not want to deal with leaks, so I used a stock gasket & just milled them a little more. Runs fine on 93 octane.
