GTO or Ws6
Pros of a WS6, more agressive look, can fit wider and bigger wheels, fairly inexpensive to mod and many abundant parts. Easier to launch.
Cons of WS6, unfortunately the best interior 1982 could design (Even has the 1980's style Monsoon manual equalizer
). Weak 10 bolt rear end, the seats are horrible, chassis is about as stiff as a limp noodle, T-tops will eventually leak, the hatch area... come on forget it if you want to carry a suitcase, golf bag, anything somewhat large really.. Pros of a GTO, nicest interior GM had designed until the current CTS came out, handles nicer stock, doesn't rattle at all very solid, usable rear seats, usable trunk area, no wind noise, no leaking t-tops, sleeper look, easier to work on the engine (Engine is half under the cowl). True dual exhaust, Same engine parts availability as a F-bod / vette. great sounding radio, Even Top Gear loves this car (when called a monaro)
Cons, sleeper look, ridiculous cost to upgrade anything outside of the engine, weak 2 piece driveshaft, irs is a pain to launch, wheel hop, can't fit a decent width tire under the wells, it's a heavy car, spoiler prevents any real rear visibility.
Nothing gets more attention than a Vette or handles better (at least from the General).
Like everyone has said, if all you want is to go in a straight line, the WS6 will get you there faster. If you want to handle without being thrown around because there was a pebble in the turn, get the goat. Comfort, get the goat.
I've had 3 F-Body's over the years and loved them all. The goat is a better "all around" car than any of them. It would take a lot of money to get it as fast as my TTA was, but high 11's/low 12's is going to be good enough for me with the goat
It is all what you are after in the long run. Get/drive whatever you want. They are both great cars so its a win with either.
