Has anyone accually done this?
Old Apr 30, 2008 | 04:17 PM
mypoorLS1's Avatar
Default Has anyone accually done this?
I'm calling all over the place to find something to clean out my head bolt holes. Only one I can find has to be made and they wanted like $160 for it. Do people really pay this for a tap or use something else to clean the bolt holes.
Old Apr 30, 2008 | 04:18 PM
phoenix1987's Avatar
ARP makes one for the LSxs. Around $54.
Old Apr 30, 2008 | 04:20 PM
McCs WS6's Avatar
take one of the stock bolts and grind a strip on it.. (up and down on the threads) it will clean out any junk in there.. also get long q-tips like medical ones.. that works well too
Old Apr 30, 2008 | 04:31 PM
mypoorLS1's Avatar
That's what I accually had in mind.
Thanks guys.
Old Apr 30, 2008 | 04:48 PM
danf1000's Avatar
canned air with a longer straw taped to it. Looked like bogies when it came out.
Old Apr 30, 2008 | 05:17 PM
Randy WS6's Avatar
I did the Grind stock head bolt and works grate, Because GM uses a loctite stuff on the bolts and need to be cleaned out of the threads, I put a peace of 1/4" vac. hose on the end of my shop vac. and sucked out the water and debree from the theads.
Old Apr 30, 2008 | 10:22 PM
socal's Avatar
Thanks guys.
this is what we did but diped the threads in grease and then sprayed parts cleaner in the hole and blew it out w an air hose
Old Apr 30, 2008 | 10:28 PM
Juiced's Avatar
a wire brush for a .45cal will work and they are cheap at walmart. really helps clean everything out.
Old May 1, 2008 | 08:51 AM
fast377's Avatar
Works perfectly. Also do that straw with a vacuum thing to suck out all the coolant.
Old May 1, 2008 | 10:41 AM
GuitsBoy's Avatar
WetVac + Straw = The good life.
