what is the compression on an ls1?
Old Aug 5, 2003 | 12:01 PM
2000ws6transam's Avatar
Default what is the compression on an ls1?
all cylinders are @ 209 and #2 is at 214 is this normal for ls1 heads?
Old Aug 5, 2003 | 12:19 PM
30thWS6's Avatar
Default Re: what is the compression on an ls1?
Sounds normal to me. Depends how long you cranked the engine for while performing the test, and whether it was at WOT or not. Are you concerned that it may be too high?
Old Aug 5, 2003 | 12:29 PM
no that it is too low, put ls6 heads on! i i cranked it over 6-7 times per. but did not hold it wide open
Old Aug 5, 2003 | 02:07 PM
30thWS6's Avatar
No way is that too low. Standard procedure for doing a compression check is 5 cranks at WOT. At 10:1 compression you should see about 160-170psi.
Old Aug 6, 2003 | 07:13 AM
thanks i am going to rule that out as a problem!!!
