rebuild
Old May 11, 2008 | 08:04 PM
transam981331's Avatar
Default rebuild
How much does it roughly cost to rebuild an ls1
Old May 11, 2008 | 08:40 PM
99blancoSS's Avatar
All depends on where you live and whos doing the work, what parts you go with and how extensive a job you do. I would charge you about 800 minimum just for block work, line honing and such( balancing). Then you add in parts and getting the crank magnafluxed.. my guess is about $2000 with you doing the assembly. Just an off the top of my head guess, could be more could be less.
Old May 12, 2008 | 07:47 AM
98TransAmNL's Avatar
I'm in the process of getting it down now. I have an overlapped connecting rod bearing and a crank that is scored (not sure how bad). I am not doing any of the work myself. I'll keep you posted on the extent of what parts I am going to need and the labour costs.
Old May 12, 2008 | 09:04 AM
Nightrydass's Avatar
U kno; i was wondering the same thing. i kinda figured on about $2K. That's if nothing is bent, broken, and/or otherwise fucked up. Then, by the time u add in any mods; H/C/I/E/Tune (parts AND labor) it is probably going to cost MORE then a turn key long block. SLP has their 402 for a hair over $8K. I can't justify spending the same or more on my stock LS1 and end up with less power and no warrenty. At least with the long block all the parts have a warrenty as well as the labor, and everything is matched and tested.
i dunno
Old May 12, 2008 | 09:09 AM
bjamick's Avatar
I did my complete 347 forged for 3gs. Thats for all machine work and parts.. Cost me $275 for machine work (ex. Block vatted, Bore/hone, Balance (flywheel, crank, pressure plate, and rods), installed cam bearings, Turned my crank). So actually its not bad at all if your doing a stock rebuild.
Old May 12, 2008 | 09:20 AM
yea but im not! lol.
i have been reading A LOT on internal **** and really thinking about what i want. I just can't see it cositing me significantly less then $8K; i can't justify putting that into my stock block when i can get a 402 for the same price.
I mean h/c/tune is going to be about @3K just in parts.
I have some piston slap so i would get my bottom end redone as well.
by the time u factor in labor and parts, as well as machining. it MIGHT be $1.5K less. That is assuming nothing is fucked up and needs to be replaced. Also; knowing hoe i am i wouldn't replace any rebuild pieces with stock OEM replacements. I would def use ARP studs and better barings. So i wouldn't be saving anything.
Then there is the fact that a long block is warrentied, and all parts are matched.
If you're going for stock, then it is worth it. I just don't understand why people spend so much money modding their stock block when they could have a long block with better performance for the same price.
Old May 12, 2008 | 09:06 PM
why dont u just find a used low mile shortblock?
Old May 13, 2008 | 12:21 PM
BAD2000TA's Avatar
Why not a 402 from Scoggins? About $4200 for the short block. Otherwise, bore/hone your block for $150, buy new pistons, and if you need a crank, there are plenty of stock ones for sale cheap. Upgrade the rods for $300-400. Done. All depends on what you want then you're done.
