broke a valve!
Old Jun 1, 2008 | 04:31 PM
dawiz's Avatar
Default broke a valve!
just cruising in traffic doing about 35mph. havent beat on the car in weeks. never mechanically overrevved since ive owned it. car has 60k miles. a pretty healthy cam in the mid 240's. Patriot Extreme dual valve springs with titanium retainers.
the valve kissed the piston and left a little eybrow. new heads are on the way.
Old Jun 1, 2008 | 06:36 PM
Shawn MacAnanny's Avatar
Did it break a piston? Or just bend a valve?
Old Jun 1, 2008 | 06:50 PM
dawiz's Avatar
nope valve broke and it jsut dinged the piston
Old Jun 1, 2008 | 06:59 PM
Thanks! Now I'm bumping my limiter from 6400 to 7000rpm. Sorry i didnt realize i had images turned off in my browser.
Old Jun 1, 2008 | 09:03 PM
ShevrolayZ28's Avatar
Bummer!
Supicious that it's just one cylinder. What else failed?
Old Jun 1, 2008 | 09:36 PM
daniel6718's Avatar
hmm id like to know why? springs too strong?
Old Jun 1, 2008 | 10:43 PM
LS1C5Vette's Avatar
You going to **softly** "sand" those ridges down or replace the piston?
Old Jun 2, 2008 | 06:21 AM
dawiz's Avatar
nothing else broke. just the valve.
id like to know why too!
yes, i am going to smooth the piston back down and put it back together with the new heads.
Old Jun 2, 2008 | 07:28 AM
vettenuts's Avatar
See if the seat of the valve is mushroomed at all. Were these hollow valves?
Old Jun 2, 2008 | 09:12 AM
dawiz's Avatar
the valve is not mushroomed. and these are stock valves.
Old Jun 2, 2008 | 10:22 AM
socmguy's Avatar
Restricted User
OMG, never seen that happen before.
Old Jun 2, 2008 | 11:23 AM
5_02ls1's Avatar
I had this happen on a 5 liter ford but I wasnt so lucky it ruined the whole engine...
Old Jun 2, 2008 | 11:50 AM
Of course you've checked the lifter, cam lobe, rockers, springs etc. And hopefully there's nothing wrong the lower end. Sure you didn't break a rod bolt, rod bearing, wrist pin, or connecting rod?
Do a thorough inspection before putting new heads on.
Old Jun 2, 2008 | 01:45 PM
dawiz's Avatar
lifter looks fine. i assume the cam lobe is fine since the lifter is not damaged at all. the rockers look fine. i plan to replace at least that one in case it was stressed at all when the valve broke.
the shortblock is still in the car so there is no way to check rod bolts etc.
Old Jun 2, 2008 | 04:41 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
I wouldn't consider that a small eyebrow. I'd check your valve guides. Any sort of lateral play in them could potentially cause problems with the spring properly controlling the valve.
Old Jun 2, 2008 | 05:33 PM
dawiz's Avatar
im putting on new heads. i could care less about the valve guides at this point.
Old Jun 2, 2008 | 09:14 PM
cam75w/ls1's Avatar
The motor I'm building right now is a iron 6.0 out of a 2003 HD2500. It originally dropped a valve just like that and shattered the piston. An old lady owned it and was going to Walmart,let of the throttle to make a turn and BAM! That was it....
