what cam for a daily driver?
converter (atleast 3800 if your going with that cam)
bolts ons
cam
also with a cam that size, your going to need a new rear end and i would do the trans too b/c they will not last long.
try a search and see what others are doing to give you an idea before you go and throw a big cam on there. people are seeing 11's with a small 224 cam
I am looking at the TR224 for myself or even a 224/227 as a mild N/A cam and later to be FI motor. The 224/227 is also said to be a nice cam for a little spray.
What else do you plan on replacing when you do your swap? So far I got LS2 timing chain, Ported LS6 oil pump, ARP cam bolts and crank bolt, and an assortment of GM gaskets. Also looking at the dual spring kit TR has which should include springs, seats, seals, Ti Retainers and locks.
Like previously stated, you'll want to finish up your bolt-ons before you start thinking cam swap. IMHO, the MS3 would be too big for a FIRST cam in a DD. Maybe if you'd had a cammed car before, you'd know what to expect, but to take that big a leap all at once might become a headache for you.
Good luck!
oh and Ashes, the cam isnt going to matter if your using a small shot of nitrous. anything 200+ is when i would look into a nitrous cam so youll be fine
