PICS of my engine carnage, good stuff!!!
Old Jun 24, 2008 | 04:13 PM
brad8266's Avatar
Default PICS of my engine carnage, good stuff!!!
Ok, got the engine tore down with the exception of the rotating assembly. The shortblock will be pulled tomorow when I go get a engine lift. Two valves hit the piston so those valves are bent and need replacement but the pistons are ok. The extent of piston contact appears to be that the valves just nicked off the carbon coating on the piston tops so the pistons are ok and will be reused, the heads will get a valve job done and probably new springs while im at it. The crank suprisingly looks like it can be resued after going to the machine shop but I picked up a used one anyway and it will get machined along with the block I just bought. The only real damage I could see to the crank is the front main journal has some small scratches and the crank throws have some small scratches.
The carnage to the rest of the front end of the engine is like I have never seen before. The front main cap split in half and the entire driver side of the front of the block was split into pieces as well as the front cover and the oil pump. Pretty nasty. I am clueless as to what caused this excpet I did go to the track a few night before this. Anyway heres the pics.
Old Jun 24, 2008 | 04:23 PM
bmax's Avatar
Wow!
That's pretty bad.
Good luck on the new motor.
Old Jun 24, 2008 | 04:24 PM
SSwt00SS's Avatar
That's HOTT!!!
Old Jun 24, 2008 | 04:25 PM
jmm98LS1's Avatar
Daaaaayum!!! Never seen anything like that happen before.
Old Jun 24, 2008 | 04:27 PM
brad8266's Avatar
Yeah its pretty bad but on the upside I can reuse the eagle rods, diamond pistons, head studs, and main studs.
Old Jun 24, 2008 | 04:29 PM
2002Z28Camaro's Avatar
that sucks but its cool as hell
Old Jun 24, 2008 | 04:34 PM
McNord's Avatar
JB Weld?
Old Jun 24, 2008 | 04:36 PM
Domexitium's Avatar
DAMN! dude that sucks Good luck with the new build
Old Jun 24, 2008 | 05:00 PM
lastcall190's Avatar
I don't see what's wrong...?
Holy Freakin' God...
Good luck on the build.
It's good to know the ARP Studs can hold up to some torture
Old Jun 24, 2008 | 05:16 PM
WheelmanWS6's Avatar
HOLY ****.
damn that sux.
Lots of people 'nading motors lately.... wtf
Old Jun 24, 2008 | 05:20 PM
brad8266's Avatar
Originally Posted by McNord
JB Weld?
Worth a shot,
Old Jun 24, 2008 | 05:31 PM
Ls1Gummi's Avatar
Thats the mental image burnt in my head of what would happend if u where to spray a 800 shot!!! Damn i aint never seen a block spit up like that.
Old Jun 24, 2008 | 05:38 PM
DONAIMIAN's Avatar
I cant wrap my head around this...Ive seen split blocks, but never with the rotating asym. still intact. This could possibly be the first AL block failure, but I cant even begin to think how things happened.
Old Jun 24, 2008 | 05:42 PM
silverbandit0996's Avatar
holy $#!+.
Old Jun 24, 2008 | 05:46 PM
But I bet they aren't as excited about it as he is
Old Jun 24, 2008 | 05:49 PM
quik01ss's Avatar
Soo what made this engine split? Was there nitrious involved in this?
But, WOW i have never seen anything like this I dont even think i could have a nightmare of something like this happening.
Old Jun 24, 2008 | 06:11 PM
brad8266's Avatar
Car has been sprayed, but wasnt spraying at the time, as a matter of fact I wasnt even driving very hard when it happened.
I like how the main studs and cap are still attached to the piece of block in the last pic, Stupid motor.
Old Jun 24, 2008 | 06:14 PM
Halloran's Avatar
Dude your photoshop skills are amazing!
Old Jun 24, 2008 | 06:15 PM
03Sssnake's Avatar
Most Impressive!
brad8266's Avatar
Its not worth getting upset over, its just a motor, not too hard to build another one, just costs me some $$ that I didnt plan on spending.
