.171 pre load. Need some advice here on pushrod needed.
I marked the pushrod with a line of paint. Tightened the rockers slowly until they were at 22 ft lbs. Waited on lifter to bleed down including lightly applying upward pressure on the valve side of rocker to assure lifter had collapsed. Once the lifter was collapsed and I could wiggle the rocker I scribed a line in the paint with a razor blade. I then removed the rockers and scribed a line while holding the top of the pushrod with light pressure to assure it was still seated in the lifter cup. Did this twice on one cylinder then moved to 2 other cylinders with same results. Measured distance of lines scribed with a digital dial caliper. The rods I used to measure are 7.400.
I am thinking I need 7.300 rods that should put me around .075 preload. Would this be correct or should I go with a different legnth?
Thanks in advance.
I cannot see why there is so much pre load unless the heads were indeed milled. They are 853 castings.
I measure from what it takes to get me from the lifter being "bottomed out" to the recomended gap.
That is also why I run adjustable rockers.
That is the easiest way to be able to "dial it in" and make sure all the valves have the same/right gap.
1. With no pushrod installed snug down the rocker arm hand tight.
2. Slip PR length checker under rocker and onto lifter plunger and turn until there is no lash.
A already oil filled lifter will not collapse under this little bit of force.
I could be off +/- a few thousanths.
If I use the checker as you described then I would be measuring distance at .000 pre-load then adding to that figure to get new legnth. Correct? Doing it that way then should give me a measurement of 7.225 +/- a few thousanths giving the difference in tension one would put between the lifter and rocker arm. Not everyone is going to tighten it the exact amount. Add .075 to that comming up with 7.300 compressing the lifter .075 also.
With that in mind, would it be safe to say I need a 7.300 pushrod or should I just buy a checker and measure that way? I hate this non adjustable pre-load crap. As good as the LS1 is one would think GM could have come up with something else.
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
And it doesnt matter how much you tighten the rocker when performing the check because you cant push the rocker down farther then the rocker boss surface anyway so the rocker only needs to be snug before you slip the checker under.
You guys are making rocket science of something simple.
Link to adjustable pushrod usage
Guess I'll hit up Keystone Performance Monday for a checker just to be sure then order up some pushrods.
Sorry for
If you checked it a bunch of times in different spots and it is consistent then you want in the 7.34 area, that includes the 1/8th of a turn and a .080 desired preload on the lifter. 6.8 +.456 + .080
