MS4 , vavle springs and fuel pump + 150 shoot
Old 07-09-2008, 04:31 AM
PONTIAC SLP's Avatar
Default MS4 , vavle springs and fuel pump + 150 shoot
hey , i bought MS4 but i am puzzled between PAC springs 650 lift and patriot gold springs what of those two springs is better ? and i am planning for 150 spray i will buy 42 injectors , do i need fuel pump or not necessary
thanks
Old 07-09-2008, 08:55 AM
98mysticZ's Avatar
i had svo 42lbers in mine and had a 150 shot but are you going wet or dry.... i also bought the spring kit from texas-speed that they reccomend with the cam.. and u will need a fuel pump mine is the walbro in tank 255
Old 07-09-2008, 09:43 AM
smokinponcho73's Avatar
i think it is the patriot gold extremes you will need
Old 07-09-2008, 10:00 AM
wet with tnt f1 , how about yours wet or dry ? what valve springs is yours ? i ordered from LS1SPEED gold springs and they said they will ship in 1 week , is the fuel pump is necessary or not
Old 07-09-2008, 10:02 AM
thanks , lets see another posts
no title here
skyhighsami's Avatar
He said that you would need a pump and that he had a Walbro 255
Old 07-09-2008, 10:57 AM
98mysticZ's Avatar
i used the prc springs and i was on a dry shot
Old 07-09-2008, 11:21 AM
Prerun4fun13's Avatar
I have the Patriot Dual golds. I like them because they come with Super 7 locks which are twice the size of the PRC locks.
Old 07-09-2008, 11:23 AM
dankl's Avatar
might not need the fuel pump, but most likely you will. So might as well get it done and outta the way. I needed a fuel pump with much less cam than the MS4...
Old 07-09-2008, 11:27 AM
sidewayz28's Avatar
patriot golds, Racetronix plug and play, 39# injectors...wet shot
Old 07-09-2008, 11:46 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
We use the PRC platinum spring kits with the MS4 combos that ship from this shop. You have to be pretty careful picking a spring kit because not every spring kit is the same. We build the PRC retainers & seats in the U.S. While that doesn't sound important, it really is. A lot of the imported seats being used by other manufacturers have varied by .030"+ on install height from one valve job to another!!
This could really cause a huge problem when your trying to run a cam near the max useable lift of a valve spring.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 07-09-2008, 12:09 PM
dankl's Avatar
^^^very true. Good point for the OP
Old 07-09-2008, 03:09 PM
miller456's Avatar
Im not sure if you ever stated if you are m6 or a4? with a spring only rated at a .650 lift and with the info Jason just provided you will be pushing that spring to the max. I hope that if you are manual you never mechanically over rev and if you are auto your shift points are set to the T. I would go with the PRC kit since it seems to be the most commonly used with the ms4 combos. I personally run the PRC kit while it may be a little pricey, it cost much less than a spun rod bearing or other problems like a spring failing and ptv slap.
Oh and Jason your car has some sick dyno number's especially from a mustang dyno, that thing has to be a lot of fun
Old 07-09-2008, 03:33 PM
dankl's Avatar
+1 on that. Jealous of the Twin Turbo Vette
Old 07-10-2008, 03:27 AM
thanks guys and special thanks for u jason , i'll talk to Bryan at ls1speed about the valve springs .
Old 07-10-2008, 03:32 PM
i talked with Bryan @ LS1SPEED he said i should run with patriot extreme springs for MS4
Old 07-10-2008, 11:29 PM
LSWNDR's Avatar
sidewaysz-28 said it my friend for sure
