LS1 and 5.0 Mustang same firing order?
Ok, I was searching this myself but just to clear up the firing order issue:
5.0 firing order is 1-3-7-2-6-5-4-8
BUT instead of the cylinders being number 1,3,5,7 driver side and 2,4,6,8 passenger side it starts on the passenger side 1,2,3,4 and continues front to back on the driver side 5,6,7,8
SO, if you were to renumber the cylinders like an LS1 the firing order would be: 2-6-5-4-3-1-8-7 where as the LS1 firing order is 1-8-7-2-6-5-4-3
Please explain how being that the ORDER is the same that they would be firing differently...
I am sure I am missing something just don't know quite what...
If this helps here's the valve adjustment info (all I can find after an hour of searching $hitty mustang forums)...
Ford (5.0 HO, 351W, 351M, 351C, 300)No. 1 cylinder at TDC compression
Adjust exhaust valve: 1, 2, 3, 4
Adjust intake valve: 1, 5, 7, 8
No. 6 cylinder at TDC compression
Adjust exhaust valve: 5, 6, 7, 8
Adjust intake valve: 2, 3, 4, 6
The LS1 and 5.0HO (351 etc) are the same as is another OLD GM motor (Cadillac). The GM(caddy/LS) and the ford firing order are all the rage now in racing motors. Most GM/chrysler, some ford (numbered different) use the old stand by 18436572. The LS/caddy/ford style is supposed to be better on the bottom end and make a little more power. 7-4 swaps are popular as well but that is only part of the change.
5.0L = 1-8-7-2-6-5-4-3 (move cylinder #1 to the front)
LS1 = 1-8-7-2-6-5-4-3
