first ls1 build, a few simple questions
i tried another bolt in the same hole, SAME THING. I'm trying not to freak out. What do I do from here?As for the oil pump, it looks like a Melling so check for clearance around the timing chain when you go to put it on. It usually hits right around the flange where the pick up tube bolts up. Also, get some clearance between the pump housing and the drive gear. I do this by putting on the housing first and sticking in a few .003" shims, like from a feeler guage, between the housing and the oil pump gear and then tightening the pump bolts down. This helps the pump last longer, and not wear so much.
I know the sales guys will tell you not to degree the cam, but if you have the tools and knowledge to do so, that's the best way for any buildup. You can't pick up on how to do that correctly over the phone, there are many websites and books that show how to degree. I do a ton of camshafts, and if its something you don't do everyday, I can see it being a hassle.
Also, I just got back from Ace Hardware, with the Helicoil kit. I had to buy a separate handle thing too (Irwin). Now I the cam retainer bolts thread into the helicoils just fine (M8x1.25x20mm), but I'm wondering about two things. The length of the coil is shorter than the length of the bolt. Should I "double up" the coils in the block? Or will one coil be fine? And then I also noticed a little "tab" at one end of the helicoil. Do I cut that off or is that supposed to be left on when I thread the bolt into it? Here's a pic:
You guys kick more *** than Bruce Lee for helping me along my build! I definitely get piece of mind double checking with you dudes on this thread.
Yes, if the spacer is upside down, it will block nearly half of the oil passage. Just stick the oil pump bolts in the holes on the pump, and slide the spacers on like you're about to install it, and you can look and see how it lines up with the passage on the pump.
Ok, here's an update: I got the helicoil done, and the all four cam retainer bolts are torqued to 18 ft lbs!
The helicoil installation actually wasn't as bad as I thought it was going to be. First time jitters I guess. Easy instructions; here are a few pics:
This what I got from Ace Hardware:
http://zigzautonotes.googlepages.com/helicoil_tools.jpg
Here you can see how paranoid I was of getting metal shavings everywhere
http://zigzautonotes.googlepages.com/paranoid1.jpg
http://zigzautonotes.googlepages.com/paranoid2.jpg
Tapping at a steady pace, using masking tape to mark the length of the cam retainer bolt:
http://zigzautonotes.googlepages.com...il_tapping.jpg
Helicoil finally in:
http://zigzautonotes.googlepages.com...l_in_place.jpg
All four cam retainer bolts successfully in:
http://zigzautonotes.googlepages.com...ur_torqued.jpg
I made sure to blow out all the metal particles with compressed air before putting in the helicoil. As far as the little helicoil tab goes, I didn't see it when I looked down there, and the instructions didn't say anything about it, so I just torqued the bolt down. I left it overnight and double checked the torque setting just to make sure, and it's still at 18 ft lbs so I think I'm ok.
Next up is the double roller timing chain!! I'm wondering about something though...i'm looking through my LS1 rebuild book (by Chris Werner), and it says that there are two different kinds of oil pickup tubes! it says one type necks down near the end before bumping into a flange, and requires a green gm o-ring. the other type does not neck down and this type requires a thinner o-ring that is either blue or black. WHAT THE HELL? i don't know what "neck down" means, but that's what it says in the book. it doesn't show a photo of the two types, only a photo of the one that doesn't "neck down."
I did a search on tech and it seems that the general consensus is that I should get the blue o-ring, and that the green ones are for truck ls1s. I think I saw a thread that said the green ones are for LS1 oil pickup tubes that flare out at the end going into the oil pump. So I think I'm good getting the blue o-ring. What do you guys think?
Thanks again guys
I put the oil pump on the crank, used the four bolts from the Rollmaster kit to steady it, centered it with 0.002" feeler gauges, put the inner gear in, and put the oil pump cover on, and went to torque those oil pump cover bolts to 18 lb ft, and five of them spun.
AND, ONE OF THE BOLTS BROKE OFF at the head.
I guess that's what I get for not using new bolts. Looking at them now, they do look scrawny and if the engine is 10 years old and they've been torqued often, they've had their day.Oh well, it gave me an excuse to get a new oil pump:
SLP PN 55001. got it from jeg's so it should be here this week. should be fun
Be sure to check for chain-pump clearance. I know that the Mellings, even the 10296, need to be clearanced for the timing chain.
-Kent
http://zigzautonotes.googlepages.com/SLP_oil_pump.jpg
The oil pump cover bolts I torqued to 106 inch pounds. Now that is not a lot of torque, so I'm a little worried, but that's what you guys, LS1Howto.com, AND the GM Service Manual say to do, so I probably shouldn't be worried huh. Only thing is, those are torque specs for a stock oil pump, and mine is aftermarket, so I'm hoping it's still torqued properly...
KCS, I checked for clearance too, thanks for the tip. The chain clears the pump housing.
Halloran, it's been a few hours buddy. Hope you're still not cooking your balancer!
